GT4RS front axle lift decision
#46
#47
Parked my 981 next to the RS this past weekend. I believe this car was parked in the lifted position. But that lip is definitely longer than the regular gt4 so that is the issue rather than the ride height.
#48
#49
It also shows nicely the difference between the standard headlights (top) and the PDLS LED headlights (bottom).
#50
The FAL system raises 30mm at front wheel suspension. This equates to 42mm increase clearance of the front splitter when engaged. A problem is that it drops the rear by 11mm (due to the fixed geometry of the rear suspension when the front suspension is lifted) .Angle of entry is 8-9 degrees taken 'square' but 10-12 degrees entering at an angle. Exiting a driveway the rear diffuser, if the FAL is engaged is at risk. Suggestion is not to engage the FAL till the rear has cleared the driveway culvert.
The front lip splitter is also 'attached' to the vehicle with two flexible 'rods' that can flex sideways to allow the splitter to deflect upwards if you hit something. Good design.
#52
After two weeks I have not scraped at all. An observer positioned when reversing out of driveway, I would hit rear diffuser if FAL engaged. So I have FAL off till rear clear, engage FAL to allow front splitter to clear.
#53
600mi so far on my car. 0 scrapes. In and out of gas stations, bumpy roads fully compressed suspension etc etc. No scraping.
Scraped more on my 2018 GT3. So who knows. Would I have ordered FAL given the chance? Probably.
But so far on the 4RS I don’t miss it. I’ll update if I do end up scraping.
#54
I think I have scarped my front lip (GT4) a handful of times but the rear diffusor takes all the beating from living in Brooklyn
My 718 GT4 Euro Delivery Thread
Contact me for the best pricing on Quality Parts
- alex@lepetitgarage.us
LePetitGarage.us // @_lepetitgarage on Instagram
#55
As mentioned...the major problem is the rear diffuser and the aero devices just after the front wheels....these last ones are held by just 3 snap-on clip/rivet, just found that I was missing 2 on each side.
#56
Front lift is a must here in Houston. 80miles in on this one after I picked it up after being Xpel Stealth wrapped.
My 3RS coming in December will also have the front lift. People that dont like to keep their cars need to remember the front lift is a big deal on resale.
Bodibedo (06-04-2023)
