Cylinder deactivation not disabling?
I have a manual GT4 with an aftermarket exhaust and I keep hearing these weird thunk or thump sounds, usually at around 3000 and between 4000-5000 RPMs, always when I let off the gas.
I was thinking it's just the Variocam engagement points or whatever because I have auto/start disabled always (which should not enable cylinder deactivation right?). But today I was testing out the cylinder deactivation and it sounds exactly what I'm experiencing described in the first paragraph (but at higher RPMs).
Is it possible for cylinder deactivation to function when the start/stop button is disabled? Is it possible for it to deactivate above 3000 RPM, especially at 4500-5000RPM? Do I have a faulty car somehow?
Cylinder deactivation is disabled if you deactivate Auto stop start. The window in which it works, in my manual GTS 4.0 anyway, is quite narrow. Never above 2,400 RPM (or 104km/h) and only under really, really light load. I think it's 2,400 RPM, been a while since i've driven. But for highway driving it basically doesn't work because the highway limit here is 120km/h so you're always driving above the max speed for it.
With the standard exhaust and valves locked open, when one bank deactivates it's sound like absolute trash and hurts your ears, you can't miss the fact that it's working.
The following 2 users liked this post by Larry Cable:
patdonahue (06-12-2022),
UncleDude (06-11-2022)
With stock exhaust with valves closed you literally can't hear it. You can feel the lack of power, but unless you really listen out it's pretty impressive how there is no difference in sound.
I'll have to get a video but this is what I'm experiencing exactly.
Start/Stop off
Run car to 6k RPM in 3rd or 4th gear
Let off gas so it falls to 4500-5000
Really loud "thunk" from exhaust
Apply a little gas, thunk goes away
Let off gas again and you can hear it again
like I said, it sounds exactly like what the cylinder deactivation sounds like at low RPMs. I'll take it in next week to see what the dealership says.
Start/Stop off
Start/Stop off
Start/Stop off
The general RPM ranges and occurring during RPMs going up/down sound like a valve issue.
Cylinder deactivation is not in play for the driving your describing.
Larry Cable (06-12-2022)
Received 3,447 Likes
PSE disabled by disconnecting vacuum lines on my Kline. Ok I'll see what the dealership has to say
Well if Eric did this it's done right but it's not just unplugging the valves it's plugging the vacuum lines from be the engine that opens and closes them ...
