Alignment problem, 718 GTS
The workshop has problems with the right front. On the left side, they have succeeded with -1.3, but only -0.6 on the right.
What could be the problem, could something be bent or damaged?
Remove the plastic battery cover at the rear of the frunk and take a photo of the top of your struts for us. As mentioned above we should be able to see by that if the workshop knew what they were doing.
The workshop is working with the car right now. I asked them to look for bent parts as struts and shock asobers ( piston )
The work of adjusting camber to the front is otherwise quite simple.
Loosen 3 nuts and then push everything inwards. Get back with pic on strut
