How do your tires look?
Can you guys post pictures of your tire edges (not the treads)? I have the Dunlops race Maxx 2's, had the car for 2 years now, 2500 miles - the edges look kind of more worn than they should? Never had any camber work, never drove it rough or did any sliding. Anyway, I'm debating on going to the track in August for the first time with this car. Want to see how your tires are wearing in
I have 2 quasi track days. One was a PCA national school so doesn't really count IMO since it was instructor training, more us screwing with each other trying to roll play the worst student we've encountered, only hit 1.35g that day and no tire edge wear worth mentioning, and another tonight where I drove slow (always had a student in the car) but hard enough to where I was engaging the aids continually by rotating my *** on corner entry and throttle steering out of some corners. 1.61g hit there on cup 2s. Tire wear is rubber is rolling itself off and IMO it's just a a bit of edge wear.
No shims yet, no alignment yet (but mine came from the factory with the camber almost maxed on the front end for adjustment). I had zero edge wear up until I went to the track. 2200km on the car now.
When was the last time you had the alignment checked? If you've never had it checked, you could start there. Also, you can make minor alignment tweaks with the stock suspension.
Here's a photo of the front and rear edges on my Sport Cup 2s at about 2650 miles if that helps. They are holding up pretty well after three autocrosses and about twenty fast laps on COTA a couple of months ago... plus some modestly aggressive driving in general. I do have the camber at about -2.3 degrees front and -1.7 rear.
It might be handy to post pictures of your tire edges/treads as well since the brain trust here might be able to help more if they can see what you mean.
On my 2020 Spyder, Dunlop Maxx Race 2 right rear, mostly street with some light track days:
2 track days. Minimal road miles. 50% tread depth worn from fronts. Rears about 25% worn.
front(3 degrees camber)
rear (2.5 degrees camber)
enduro (05-13-2022)
I'm doing pretty much only track miles now so inner wear is less of an issue. I completely destroyed my outside edges with only 2.5/2.0
Larry Cable (05-13-2022)
