The 4.0 is Special
#31
The following 2 users liked this post by batasrki:
baege (04-10-2022),
Mousejunior (04-11-2022)
#33
I might be interested in coming up to Toronto for a road rally. I was also thinking about putting something together for this summer on Rt 44 from Lock Haven to Coudersport, stopping at Hyner to watch hang gliding and have some lunch.
#34
#35
#37
As far as my knowledge goes the engines that are developed by the GT department is usually used in some sort of a competitive motorsport environment in a Clubsport or Cup series. The 9A2 Evo motors are not used in any racing variant (718 Clubsport uses previous 981 engine, and the new variant uses 992 GT3/718 GT4 RS engine). I think time will tell how good this engine is long term. It does produce a healthy amount of torque and appears to be a strong engine.
#39
I had a 981 Cayman GTS with a stick for the last 6 years. I put about 52k miles on it and tracked it 3-4 times. I recently traded it on a Boxster GTS 4.0 with a PDK. Unfortunately, I have only gotten to put a few miles on the Boxster as I have been out of town. The additional power, particularly at lower rpm, is a big difference. The exhaust on-throttle sounds great, but I miss the 981’s burble when you lift the throttle. It is great to have a convertible again.
You sir, clearly have most excellent taste in cars …
The following 3 users liked this post by ~NorthWest~:
#40
#41
It’s top down weather and my exhaust system is opening up a little now - such beautiful 4.0 notes when the top is down!
#42
GTS 4.0 PTS BRG with Expresso/Cognac
Just delivered to NC after film and ceramic. I have 48 miles already. Different from my previous 981 Cayman GTS but a very strong car. Perfect companion to my 981 red Boxster GTS.
I would love to find out if this is only BRG Cayman ever produced. Any suggestions on research much appreciated.
The following 5 users liked this post by Bmartin:
Alpha Ice (04-14-2022),
D1coach (04-14-2022),
Frank Abe (04-14-2022),
hellboy_mcqueen (04-14-2022),
maschinetheist (04-30-2024)
#44
Also, as someone who has manifolds and an aftermarket exhaust, I can confirm I get plenty of burbles on overruns and general decel. If I shift from 1st to 2nd in the 4-5k rpm range, I can even get a fairly loud pop....I'm not sure how much of a fan of it I am. But if we ever get something above 50 degrees in MN when I'm not stuck working or golfing I'll be sure to grab some clips.
#45
