Soul LPs vs. Akra LPs?
I've decided to begin by changing out the link pipes on my GT4, I see these two are recommended the most and I was curious if anyone could tell me what is going to be different between them? This is quite a hard decision for me.
Soul is stainless steel and has no heat shielding
Akra is titanium and has heat shielding.
Virtually no performance difference. The different materials may sound slightly different.
can’t go wrong either way
2020GT4 (08-21-2023)
If I am in the market for an OAP, I would get the Flat6 in-house one, it's stainless steel with heat shield. A pipe is just a long cylindrical tube, there is nothing magical about it (with the exception of the CG one with high flow filter)
It is debatable but how many exhaust pipes have heat shields as it is? You will not notice a difference IMO. If it really mattered Porsche would do it. Akras are not what they used to be as well - you are paying a lot for the name.
The following 6 users liked this post by jwr9152:
Alpha Ice (09-10-2021),
Balloonmeister (09-10-2021),
jcmer22 (09-09-2021),
Larry Cable (04-02-2023),
ngamountains (09-09-2021),
and 1 others liked this post.
BTW are the Akra OAPs even available in N.A now?
Yes, the factory pipe is heat shielded, because it’s connected to a large easy bake oven called the GPF/OPF.
The GPF restriction generates heat as well as the burn cycles in the monitored cars.
Prior to the 718 GPF cars there wasn’t much discussion on shielded OAP pipes.
FWIW I am running unshielded OAPs now for testing but for long term use I consider it a requirement.
The following 2 users liked this post by JCviggen:
jwr9152 (09-10-2021),
