Soul Perf Valve Controller Thoughts?
Loving the Spyder so far!!!! But I'm annoyed by the valve controller in exhaust mode... open in low RPMs, then goes off, then back on around 4k. I'm looking at Soul Valve controller vs Cargraphics 2 unit. The price difference is large, has anyone seen the two compared side by side?
Can they both be programmed to homelink?
I have CG programmed to homelink. It works fine. I don’t toggle on/off via homelink nearly as much as I thought I would though.
Yes that is what I meant by toggle. I pretty much just leave valves open all the time. I played around with it the first few days but realized I prefer the sound at all rev ranges with valves open. I have a gts though so it may sound a bit different for me.
No sorry that’s not what I meant. I have one homelink button set to correspond to the valves open function and another homelink set for valves closed. I don’t think you can toggle from one button but not absolutely sure.
does the CG remote have one or two buttons to control the valves open/closed? i.e is it a toggle or a mode?
2 way I believe it is either valves open or closed.
