How is the "standard" trim?
Is there anyone that has the 'standard' trim in a GTS 4.0? On the configurator it looks ok, but is it cheap and/or plasticky looking in real life?
Is brushed aluminum or carbon fiber (or leather) a necessity? Or does it look fine without one of those $1000+ choices?
Thanks.
Thanks.
It looks like silver plastic trying to simulate metal. I sat in 3 different caymans with it this morning and it's not terrible, but it gets fingerprinted and reflects sunlight. I was debating cutting it off of my order to save the $900, but that's a pretty small amount compared to the price of the car, and I ended up going with the brushed aluminum.
Which interior are you trying to pair the trim with?
I saw brushed aluminum on the 25th Anniversary and that’s beautiful.
Thanks for the input.
I ended up going with the brushed because it matches the bar behind the seats and somewhat works with the silver seatbacks. Here's my build if it helps at all : http://www.porsche-code.com/PN1RR7M2
Now too bad the shifter does didn’t match.
My SA talked me out of brushed aluminum and I kept the standard trim as he said it matched the door pulls better ( in the BGTS) . I will see when I get it if I regret it, as I do like the brushed look as I had it in both my BMW’s.
Paiceyfan (06-30-2021)
I think the brushed aluminum dash trim is perfect for a Cayman because then it matches the door sill plate and that huge brushed aluminum piece that goes across the rear hatch connecting the oil and coolant fill holes.
I have a GT4, which has brushed aluminum interior dash trim standard.
I had it on my 991.
Definitely plasticky looking.
Just like any other options, don’t look too hard at the upgrade that is available. For me personally, it cannot be ‘unseen’.
Full leather, deviated stitching, alcantara visors….there is no end.
My own personal pet peeve is interior trim should match door sills.
Good luck going down the rabbit hole of Porsche options, aka Porsche tax.
The following 2 users liked this post by Dyim:
JBSea (07-01-2021),
sonicworld (07-01-2021)
Brushed aluminum shifter
You can order no charge optional brushed aluminum shift **** that matches the brushed aluminum trim. I am very pleased with the optional brushed aluminum trim and standard black interior with non-ventilated black leather 18 way sport seats in my CGTS 4.0.
The following 2 users liked this post by Dnomis:
P-car-Vancouver (06-30-2021),
sonicworld (12-17-2021)
Personally not buying GTS for its interior. Its a sports car, minimalistic interior is my approach. I only went 'extended leather' with remaining trim stock. Rather spend that $5-7k on other options/upgrades.
