DYI black Spyder logos
Yep, I went over them with 400 grit sandpaper. This was a bit challenging because of the adhesive backing that needed to stay affixed and the intricate curves of the emblem. Plus, the chrome is more durable than I expected.
I considered using a Dremel or die grinder but the SEM paint says it's OK to apply on chrome so I took a chance. Time will tell now.
Received 3,460 Likes
I removed the Targa emblems on my last P-car and had Eric at bumperplugs.com paint them and plan to do the same this time, in Racing Yellow. I know I will be able to remove mine and reinstall them so I will not be buying new ones; however, here are the part#s in case someone needs them:
981-559-275-00 and 981-559-276-00
FYI: They are $330 the pair shipped from Annapolis Porsche to me in FL.
The following 2 users liked this post by Bob Z.:
Jeff Jones (05-23-2021),
Spyder718 (05-23-2021)
I like the matte black logo look as well but would like to have a factory finish if possible.
Just now eyeballing it with a ruler. It looks like the rear matte black Spyder logo has the same dimensions as the ones on the trunk flaps...maybe?
https://www.suncoastparts.com/product/sku718spyemb.html
https://www.suncoastparts.com/produc...1SPYSLOGO.html
Anyone care to confirm before I order 2 of these? Thanks.
In case you havent noticed, THey do this stuf on purpose to encourage you to spend money. If you want painted washers, you pay. But the door handles come stock with exterior color paint. And the wing on a GTS comes stock in exterior color paint. My point here is if you're going for a "black theme" or an "exterior color theme", you are gonna have to spend money somehwere to get everything to sync up. If you don't spend the money you will have a mix of black and exterior color trim pieces. Let's not forget about the chrome "PORSCHE" across the back. They will happily black it out for you!
The pins are not needed since new 3M tape would be applied...most emblems use just 3M tape without pins.
Anybody have a picture of the back of one of these? I would like to know where the pins are so I can carefully remove the emblem for re-use.
SBARacing (05-26-2021)
