Spyder Rear Trunk
So can the Spyder rear trunk be opened with the cars top closed? It appears the trunk release button in the car and on the key fob is disabled when the top is closed.
Sorry if this has been discussed before, I didn’t find a related topic.
Registered User
I haven't had mine for long but it seems you have to detach the little side wings to get the trunk lid up. I suppose you could just cycle the top as if you were putting it down and detach the little wings when using it for storage. That's the only way I could think of using it.
No, with the top up the key fob and interior trunk latch are disabled.
You need to command the top down and stow the wings to open the boot.
The following 2 users liked this post by TXshaggy:
DFW01TT (03-23-2022),
Larry Cable (03-23-2022)
Considering n4v4nod's post below, I should clarify, I am talking about opening it completely, If I am out with the top down and stop to go shopping, I put the roof up and latch it at the windshield but I leave the flaps inserted in the roof, if I need to put stuff into the trunk it is available. Depending on the mood/weather I can then make the decision to stow the top or to finish the roof closing process.
If you need quick access you can do this:
Just don’t forget you need to re-latch the front when you do that. I’ve had a couple times in the few weeks I’ve owned mine where I wasn’t comfortable leaving the car open so I just latched the front and left the wings hooked to the roof. Worked out great, I was able to use the trunk when I got back then tuck the the roof away and drive off. On a road trip the stuff in the back will be whats unload at the destination. Anything we need in transit goes in the front, if traveling with the roof down, which honestly is how it will be on the interstates. Top down once we’re on the back roads.
The following 3 users liked this post by mjw930:
Just to muddy the waters, yes you can open the trunk with the top closed, you just can't do this with the flying buttresses latched in place. ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Okay, there seems to be disagreement. Which “locking” feature disables the fob and the interior trunk release? The wings being in place, the roof latch being in place, or both? I thought Westcoast had clarified it, but then Tom appears to say the opposite.
I get the wings are in the way (mechanically) for opening the trunk very far, but I assume you have to use the fob or the interior trunk release to get access at all.
As was stated elsewhere, the key fob and door sill buttons are disabled unless the roof is detached at the windshield header. Once that occurs, you can partially lift the rear deck - but be careful you don’t put undo pressure on the connected side panels. I do that to get to the bag chairs or a jacket I keep in the trunk.
Got it!
To unlatch the trunk at all the windshield latch has to be released (enables fob and interior release switch). Then, to open it more than a few inches (?), you need to unlatch the wings, because in the attached position they block the trunk from opening very far.
You can lift the trunk a moderate amount with the fins attached and people do. However the OM warns that doing so can damage the top. The fin anchors are plastic so proceed with caution.
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
I just double checked and found that the top wings (latched or not) have nothing to do with disabling the key fob or door sill buttons. The only thing that prevents their use is when the roof is “connected” to the windshield header (the car obviously knows that the roof has been latched. If it is properly latched, the buttons won’t do anything. Of course, you must unlatch the top (near the windshield) in order to easily release the top wings from the car body.
Larry Cable (03-24-2022)
Hi All,
