Suspension knock
#61
I guess there is a chance that your car might have been delivered with the transport blocks still in place (it has happened before) there is a thread elsewhere in the forum from another member who had this, and found one of them by the side of the road...
they look like a plastic clip about 3-" in length and they are "clipped" onto the springs to stop them compressing etc during transport, you should be able to spot them if you still have them installed - and if you do go straight to your dealership and get them pulled...
In reality probably what you are hearing is the helper springs moving around during compression/rebound ... which is normal...
Matthew Kidd (07-27-2023)
Larry Cable (07-27-2023)
