tell me where to stick it... (T-Design memory module that is)
So I popped my center console buttons out in order to install the https://t-design9.com/memory_module_porsche.html
on my Spyder... BUT... there is nowhere to "stick" it and I don't want it rattling around over the shifter linkage! you can't stick in "behind" the module, in front of the ashtray because the ashtray lid opens in that space... you can't stick it on the "bulkhead" in front of the console, and behind the shifter itself - there is not enough room and a bunch of wires are there already... you can't stick it on the bottom of the button unit itself, as there is not enough space to accommodate the module ... SO.... Where should I stick it? :icon107: any constructive or humorously insulting comments greatfully accepted! |
Stick it where the sun dont shine...inside the center console :P
Originally Posted by beemerb0y
(Post 17153996)
Originally Posted by Larry Cable
(Post 17154006)
that's my point, there is no obvious space upon which to attach it ... and letting it rattle around is not an option...
or reach out to them and ask. Maybe coupe/convertible and manual/pdk has different real estate under the console |
(Post 17154033)
lol i was trying to be captain obvious with some humor. There is a video either on Tdesign’s website or youtube if I remember correctly showing the install and where to stick it. Just use proper words in the youtube search ;)
or reach out to them and ask. Maybe coupe/convertible and manual/pdk has different real estate under the console https://cimg8.ibsrv.net/gimg/rennlis...2e9251b595.jpg https://cimg9.ibsrv.net/gimg/rennlis...74d6ecfa36.jpg |
(Post 17154076)
yeah, I already did, their option was to trim off plastic from the bottom of the OEM unit to make space to attach their module there...
^^^^ yeah that's an option, albeit an expensive one ... shame they could not have designed a better solution ... just my $0.02
I stuck it on the rear closer to the glovebox. Plenty of space.
(Post 17153961)
on my Spyder... BUT... there is nowhere to "stick" it and I don't want it rattling around over the shifter linkage! you can't stick in "behind" the module, in front of the ashtray because the ashtray lid opens in that space... you can't stick it on the "bulkhead" in front of the console, and behind the shifter itself - there is not enough room and a bunch of wires are there already... you can't stick it on the bottom of the button unit itself, as there is not enough space to accommodate the module ... SO.... Where should I stick it? :icon107: any constructive or humorously insulting comments greatfully accepted! I reached out to him to ask how it went.... |
Originally Posted by msile
(Post 17154104)
Originally Posted by LZRD GRN
(Post 17154107)
msile has got this installed.
I do................It was not stuck on vertically where the lid would sink in. The button console does not have much depth. I stuck it to the side toward the rear away from the linkages.
(Post 17154115)
:cheers: |
I stuck it to the front right hand side of the cavity, vertically, with the adhesive against a metal bracket. No clearance issues.
Mark |
Originally Posted by MAHack
(Post 17154122)
Mark |
