Front splitter scrapes
#31
I've scraped between 5-10 times in the 4400mi I've driven. Absolutely nothing is visible on the splitter unless you run your hand under the lip (as @n4v4nod said).
I've even pulled forward too far into a parking curb that was too tall (3 times!) - with absolutely 0 damage to the splitter.
I wouldn't worry about it
#33
Received 3,447 Likes
I have removed some small scrapes in the past but not gouges! You can try some 50-60 first finish with some fine stuff, like a 120. But you have to experiment to see what works best....I do not think you have to worry about making it worse!
#34
Same here. What I like about it is that when you accidentally go forward too far with a cement block in a parking lot. The plastic piece just bends and gives, not crunch or damage.
I curbed one of my wheels too recently, just a minor 1/2 inch but those I hate doing. Not worth the expense to fix.
#36
Oh ok, I only have 150, 400, and 600 at the moment.
#37
HAHA , love it.
Richardkun (08-25-2022)
#38
#39
I'd razor blade those burrs off and call it good. sandpaper is going to discolor a large area. you could sand it though and then use something like a SEM black spraybomb to make it black again though.
#40
Went to test drive a surprise arrival Spyder at a local dealership in June 2020. The salesman pulled the car out of a holding bay used for delivery purposes and scraped the sh*t out of the front lip. Gasp!!
#41
#42
Its much more therapeutic to buy another one from the dealer, keep it in the garage and just scrape your current one till it is paper thin and then replace it.
tigerhonaker (08-26-2022)
#44
KAP ROiK-MIB2 for Full Android on PCM 4 - Rennlist - Porsche Discussion Forums
there are other modules available for only adding the camera and those that also add Android Auto and Car Plat
Porsche 982 718 991 911carplay Box Rear Camera Bluetooth Tv - AliExpress
For Porsche Parking Assistant Front & Bakcup Rear Camera Interface Reverse Improve For Panamera 718 Cayenne Macan 982 - Vehicle Camera - AliExpress
HTH, if you have questions, perhaps go to my thread and we won't hijack this one!
