Front camera module.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
FWIW I have installed front camera's on my last 2 Porsches...
Lol if I knew what I was doing I'd be happy to post a link. My computer skills are one step up from my 81yr old dads. Hopefully this works. 😁
https://car-solutions.com/en/front-a...cm-4-0-system/
So, cutting to the chase, (and I could be wrong) this solution although priced very well, is designed for a PDK car.
Well I've got a PDK car coming in about two weeks. I know when we spoke before you mentioned your module did more than just a camera. To be honest for me all I'm looking for is to make the camera work. I did find another module as well but this one looks like it works automatically when parking. Others you have to press buttons to turn it on. I'm not sure exactly how it knows your parking but I think for the money I'll give it a go.
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/1080x1423/screenshot_20201222_073000_b3eb729f733e000d3a239ada86cc91288dbc41b0.jpg)
I couldn't link it for some reason but I got mine off eBay. The picture quality isn't brilliant but it's also not bad. Certainly good enough to see if your about to hit the curb.
The module you linked to works a bit different than that and I saw this same process on another implementation, here the front camera only activates when you shift the PDK from reverse to drive or park and then only stays on for 10 seconds (non-adjustable time), IMHO not enough time and if I am driving into my garage nose in, I wouldn't want to stop shift into reverse or park then into drive to see the front camera image and then only for 10 seconds...
Image from the rear view camera is displayed automatically on the screen when switching to reverse. When switching to Drive or Parking, image from the front view camera will be displayed on the screen for 10 seconds. Changing this time is not possible.
This solution may work for you however like another that I have seen the operation is not what I wanted, I installed the front camera in my 2016 and now 2020 Spyder to show me the front spoiler and its relationship to the curb or wall as I pulled into a spot. Both installations require me to press a button to show that front camera and I can do that at any time and even while driving and it will stay on for as long as I like or need it, so I turn it on and take my time parking as close as I desire to the obstruction.
(99) Cayman RoofCam - Rear Vision Solved | Page 4 | Planet-9 Porsche Forum (planet-9.com)
So @RavinS4 for the Spyder I went a bit different route for a couple of reasons, the 2020 comes with a backup camera now as standard and the PCM has advanced to version 4 now so different hardware is required. I also wanted to add Android to the PCM, not Android Auto but full Android, so I bought the ROiK-MIB2 from KAP Auto, this gave me full Android and the ability to show the front camera anytime. Unfortunately from what I understand the factory is shut down due to Covid-19 and not selling this unit currently, I have this working now in the Spyder as desired and will be finished in a week or so and will post some pictures and experiences about this install.
I see that there is a slightly less invasive solution (but more expensive) the NAV-TV solution 'like' I used on the 981 (for the 718 it would be the PCM 4 version): PCM4-CAM - NavTV
This may work, but TBH I haven't read the fine print in the installation guide yet... be sure you check it out fully before purchase.
theEnd (12-22-2020)
Thanks Westcoast. Look forward to your post on it with more detail. Don't really need the fully Android integration but the timer solution isn't the best for the situation I have. Hate to rush to park before a timer goes off.
A little closer inspection of the installation instructions for the NAV-TV solution leads me to believe that this may work for an 'any time front camera' setup:
• If an AUX video source is connected to the secondary RCA, press and hold the phone hang up button on the steering wheel for 2 seconds to display this video source at any time.
