Shims in the front LCA
You can find my thread was the first one about 718 gt4/spyder alignment... I also took pictures before installing the stuff.
Also, strut mounts were already "inward" from factory for maximum negative camber. With 16mm shims I reached about -2°10' front camber and +10°15 caster if I recall correctly
Below are the part numbers for shims which worked on the 981 GT4. I believe the 718 uses the same. Please double check...
1 mm shim 996 341 543 90
3 mm shim 996 341 543 92
7 mm shim 996 341 543 93
10 mm shim 996 341 543 95
From the factory, the 981 GT4 came with:
Front: 7 mm + Litronic shim (3 mm)
Rear: 2 mm + Litronic shim (3 mm)
5 mm shim 996 341 543 99
Yes my GT4 came with shims installed both front and rear. The strut tops were at max camber and with the shim it took the front to 1.7 degrees of camber.
I have discovered that as you add more shims to the LCA, it increases either bump steer OR changes the geometry of the suspension, as it makes the steering wheel jerky when navigating imperfections in the road. It isn't a tramlining thing, more of the steering wheel just moving/reacting to the road surface more in your hands. It is a little unsettling and can get annoying at times.
I am at -2.5F with the top mount maxed out and with shims on the LCA for the rest and it is noticeable. Not annoyed enough by it though to lose the amount of lateral grip you get with the settings by reducing the camber/number of shims
That is called a caster increase. Surprised that someone like you who is so in tune with the suspension and set up doesn't know this and compensate for it.
sgreer78 (04-16-2022)
I did the caster correction with Thrust arm bushings, however the increased movement of the steering wheel is still present. So something else is being altered to some degree. Not quite sure what it is, but it is enough to feel different.
My caster has been corrected to stock settings of 9.2
Adjustable thrust arms (like those offered by BBi) could be a better choice than caster pucks because they allow fine adjustment of caster.
Hmm, maybe it's just the difference in feel without the rubber bushings that the caster pucks delete. Not sure what else could change the steering feel with stock-like caster. There are some nice diagrams showing the geometry changes of adding shims here: https://rennlist.com/forums/gt4-spyd...l#post14406496
Yeah, that is my thinking as well, either the solid puck is filtering out that isolation that was present stock, and/or the amount of negative camber is keeping enough of the contact patch off the ground during straight line driving.
I have reduced that feeling quite a bit by upping the compression/rebound settings on the MCS dampers, but the wheel still feels more "alive" from stock form. It is only annoying on extreme roads now and not on all roads. So, at this point it is not enough to spend additional money figuring out or altering my alignment settings.
I thought about doing a bump steer sweep, but the costs of that are too much for an unknown result.
I went with the Elephant Thrust Arm Bushings, which are infinitely adjustable.
My 2021 GT4 came stock with 7mm shims in the front, but the strut tops were not pushed all the way in from the factory. We added another 7mm shim to each side, pushed the strut tops in and lowered the car slightly, resulting in -2.7 degrees of camber. Rides and drives great, and is amazing in both autocross and during the one track day I did.
Ron
Ron
Yep, results of more toe out could be described like @TRZ06 is indicating, tho I think he's knowledgeable enough to know this so maybe he his effect is different. Either way, my new alignment & parts are also doing it. The car 'wanders' a lot more; I attributed it to the toe out I dialed in, and I expected the effect. Mine also has the caster corrected back to 9.2°.
FWIW, my factory alignment actually had 11.4 min per side toe in up front.
I have seen toe measured two different ways and I do not know how it translates into minutes, but my front toe settings are listed as .05" each side, for a total of .1" of toe in. That is how it reads on my alignment sheet.
