Harness/Roll bar options for spyder
I want to install a 6 point harness but would rather not install eye bolts into the chassis for the shoulder belts. I am looking at options which will make it reversible/factory like as much as possible.
I came across this product which someone in a 981 boxster installed. When I reached out to them, they mentioned it will not fit the 718 but I sense they never tried yet.
Agency Power 981 harness bar
Does anyone know if there is difference between 981 and 982 spyder/boxster?
I also came across this one but it only fits the cayman from what I have been told....
R-1046 Shoulder Harness Mount
Any helps is appreciated!
Interested to see any responses myself.
There is this option from BK. https://www.bkauto.com/R_1046_Should...t_p/r-1046.htm
Can someone confirm if this will work or not?
Another option is build a custom bolt on harness bar...
A bit confusing that a GT division car with track focused suspension hasn't been designed to easily accommodate a 6pt harness.
I don't find it very confusing. There's certainly an argument that a harness bar and 6 points in the spyder is a bit of an oxymoron. If you want/need that kind of safety gear for whatever the activity may be (track, or just to feel "safer") the GT4 would've probably been the better choice.
The following 2 users liked this post by katzndogs:
Anu2g (08-16-2023),
HelpMeHelpU (11-10-2020)
I spoke with Agency Power, they are actually clearing out the harness bar because it is a low volume item. They will not be test fit/confirm on a 718 chassis for fitment.
Does anyone here know if the 981 vs. 982 chassis is any different? I could buy the product and try it. In the worst case, sell it if no fit....
Jim Rockford (10-15-2020)
DFW01TT (10-15-2020)
I just came across this which looks like may work for the Spyder with a little bit of cutting of the carpet.
RSS Harness bar
RSS Harness bar
Not at all saying this is the actual advice of professional track car preparers, but it is what I have heard from several different people on track days.
I had always heard that it wasn't safe to do a harness without a full roll cage. Conceptually, if the roof were to collapse during a roll over, you are fixed in place and things wouldn't end well. Same concept would apply to a convertible.
I still would rather be strapped inside the fixed bucket (in the lowest seat position possible) with a helmet/HANS device than risk the possibility of being thrown out of a car with a 3 point seatbelt.
Of course, a full cage is always the best but impractical and impossible on any street legal car.
I found another option but so expensive! I need to confirm it will fit the spyder.
Competition Motorsport Performance Harness Bar for 718
