Distance between jackpoints for Quickjack ordering
Yep...you can do that.
With some rough math based on the Alphas wheel base of 93.7 inches the 5000SLX may fit. That's 4 inches shorter than the GT4. Tire to tire at the bottom body line is 76 inches on the GT4. It would be snug but I suspect it would work. As I said if the Aplha is the concern you are welcome to swing by and we can slide mine under it to see if it will before you order.
You aren't far from my house. You are welcome to come by and we can go over it before you order. Center to center on my 981 GT4 is 54 inches. I don't think the 3500SLX would cover that. However I understand the 4C is likely to be trouble on the 5000SLX. Would be easy enough to do a custom lift plate for the 3500 to cover the minor additional length for the Spyder. I believe it will have the same 54 inch placement.
Thanks again..
With some rough math based on the Alphas wheel base of 93.7 inches the 5000SLX may fit. That's 4 inches shorter than the GT4. Tire to tire at the bottom body line is 76 inches. It would be snug but I suspect it would work. As I said if the Aplha is the concern you are welcome to swing by and we can slide mine under it to see if it will before you order.
The storage use I was referring to is with the 4 post I already have, but which doesn't handle the wheels off uses I want the QJ for.
You could. It would be sitting on the mechanical locks and not the hydraulics. I'm not sure hanging the suspension unloaded over that time would be a good idea. I've never stored a car that way however so I'm not certain.
The BL-3500 SLX max front to rear jacking point spread is 50.5 inches per their measuring chart, so it appears that it is too small to fit the 981, at least based on a front to rear jacking point spread of 54" specified above. Also, CaymanMatt's chart shows a range of 50" to 56" for this measurement on the 718 GTS, which would appear to just barely fit the 3500 unit. But is there actually a range for this jacking point front to rear measurement? My understanding is that there is one front and one rear recommended jacking point, yielding one fixed measurement...which is exactly what I am still trying to learn for the 718 Spyder
I rashly presume that the Spyder jackpoints are exactly the same as for my 718 CGTS. I can't guarantee it though.
