Condensation
Condensation
Washed the car off just with a hose sprinkler in the sun , ok I know not to clean the car in the sun..... rather surprised to see condensation , spoke to Porsche : "perfectly normal" "they all do that sir " anybody else had a similar experience ?
It dissapeared after a couple of hours ....718 Spyder
Only start to worry if it doesn't dry out in a few hours (or by the next day).
SpyderSwede (08-31-2020)
Do you know why Porsche designed their light housing for this to be normal? I ask because I've never owned a car where this is normal as all of the light housings, front and rear are sealed on all of the cars that we've owned. If I see condensation, that would mean to me that a seal has failed or a crack in the lens has occurred.
What I think, however, is that the alternative (requiring the lamps to be airtight) is worse: I'd rather design my headlights with good ventilation which allows for expanding/contracting air (and moisture) in a wide range of temperatures; instead of requiring them to be airtight, and then having to fix that seal or replace the whole headlight when it inevitably does break or become open to the elements.
I don't have an expert's answer to that question but I have a good guess (and quick google will come up with a variety of reasons).
I don’t think there’s anything ‘normal’ about moisture in light assemblies - Inevitably leads to corrosion of electrical fittings and it doesn’t affect all P lights - I had it on a rear light on my 992 and close inspection found it to associated with a non-traumatic crack in the lens - presumably as a result of faulty moulding ...
This is weird and first time I'm hearing of lights that are not sealed. Can you quote the parts in the manual where this is explained? Is this a new invention by Porsche? Makes no sense...
bboerit (11-23-2021)
The only online manual I could find quickly online was an old Cayenne one, but here on page 335:
Also this from the 991 manual (page 222):
Had a 718 CS for a couple years. It did it all the time depending on conditions. The forum I frequented also had this conversation and most everyone had the same thing. I would imagine, depending on where you live, you might not ever see it though.
https://www.carlightblog.com/2018/10...o-worry-about/
