718 Spyder Rear Spoiler wiggle question
My new Spyder finally had its perpetual spoiler erection fixed by way of a replacement of the rear spoiler drive unit, due to faulty internal position sensor. It now works as it should. I do have a question which I hope another Spyder owner can answer.
Does your spoiler in either tucked or extended position wiggle a teeny bit when grasped and moved?
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Do the 981 wing risers fit the 718?
If you wiggle it too much you may run into the same problem as before!
I'll clarify and indulge, here goes.
Does your "spoiler" stay very firm to the touch when extended or stowed or is it somewhat limp?
Any takers?
Just went and wiggled my spoiler when it was down. Not limp, but definitely a little soft !!
Thanks in advance.
Thanks in advance.
Thank you all for your input. I guess mine is now normal. Phew!
