On/Off PASM, do you feel it?
I have always pushed the PASM button from the very beginning so I haven't had the time to really compare the difference, until now.
So I tried and tried , but I really don't feel any difference, so I am now wondering maybe I have a faulty unit and its always in comfort mode?
Do anyone actually feel the difference?, is there another way to check this is working properly? (look for something in the shock maybe?)
I think it’s dependent on the type of road you are on. If you are on a smooth road it will be harder to tell the difference.
FWIW, this is how I've setup my 981 w/DSC controller (settings in the DSC Settings thread I started) however its noticably firmer than Normal when putting around, but soft enough to not be jarring, or get unsettled over road imperfections. I stay in Sport mode 100% of the time, while near daily driving in the heavily pot-holed DC/Baltimore metro area, with no fear, nor discomfort.
LoodorneGT4 (11-29-2022)
On my 987 Box S the pasm on/off diff is VERY noticeable. I toggle between the two many times per backroad run depending on the road surface.
PASM programming between Sport and normal was significantly different in the 981, but not necessarily "good or right" for some. The Sport setting, from the numerous reviews, seems to have changed so the dampers operate at a wider range in the 718, and are more supple at lower speeds/throttle positions/G-forces, such that it may feel close to the Normal setting, when driving casually. When you start to "lean on it", is probably when you'll start to notice the ramp up to a firmer feel in the Sport setting happen faster than in Normal, and ultimately stiffer at/near the limit.
I don't see much of a difference either on normal roads
metalone (08-16-2020)
One correction - PASM is always on, you cannot turn it off. Common misconception.
There are two modes - normal and sport. With every Porsche I have owned that was equipped with PASM, the difference was noticeable within a few seconds, particularly if the road surface was not smooth.
PASM is an active suspension and as an active suspension tI is always “on”, unless it’s broken. Even on smooth roads, the difference between sport and normal should be quite apparent whenever you push the performance envelop a bit.
It’s very apparent to me the difference in modes.
It’s quite a stark contrast.
This is on back BC roads, so they are quite bumpy.
sport+ is entirely off the table for me, it’s much too harsh and spine compacting where I live.
I would drive over a less than ideal road and then adjust PASM, it’s much more present. Perhaps you have smooth roads.
Dampers work against suspension velocity. So the differences will be bigger on rougher roads and at higher driving speeds, or during quick steering maneuvers such as a slalom. Slow steering inputs, such as a gradual sweeper, may not exhibit a big difference because the suspension is moving slowly. On a smooth road the difference will be difficult to detect for most people.
So never felt the need thus far but this thread made me press the button today on a long ride and you can feel it in the most subtle ways. Having adjustable dampers on other rides I can feel the difference immediately as said less roll tighter ride.
That's one of the many things that makes a Porsche special. The differences are subtle and don't upset the feel of the car like so many other systems that are too mushy on soft and too boy racer on firm. The fact that it is harder for some to notice the difference is a complement to Porsche in my opinion.
