718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
GT4/Spyder Driving Easy, low RPM = high oil temp, aggressive high RPM = low oil temp
Old 08-07-2020 | 01:52 PM
Underblu's Avatar
Underblu
Default GT4/Spyder Driving Easy, low RPM = high oil temp, aggressive high RPM = low oil temp
I suppose this is an effort to increase fuel efficiency In the 718 Spyder and GT4, but i dislike not having manual control over the 3rd radiator as I did in my 981 Spyder.
As i have been varying the RPMs during break-in, I noticed that when taking it easy in 5th or 6th gear, minimal throttle, basically flat terrain, my 718 Spyder engine oil temps are at their highest. As soon as I start increasing the RPMs and driving the car hard, the engine oil temps drop a good 20-25 degrees F.
i wonder if there is anyway to keep the 3rd radiator open at all times.
Old 08-07-2020 | 02:02 PM
wizee's Avatar
wizee
There’s a long and active thread about this: https://rennlist.com/forums/718-gts-...-radiator.html
On the 981 GT4, enabling auto blip (labelled sport button) would force cooler engine temperatures. Nobody has reported in that thread if that’s the case or not on the newer cars, despite multiple people asking.
Old 08-07-2020 | 02:10 PM
Archimedes's Avatar
Archimedes
See, another reason to break the car in hard...
Underblu (08-07-2020)
Old 08-07-2020 | 03:04 PM
Underblu's Avatar
Underblu
i know, i started that thread. But it was about generally higher engine oil temps in these cars
There is no Sport button in the 718 Spyder/GT4. Autoblip doesn’t appear to do anything other than auto blip.
Old 08-07-2020 | 03:11 PM
Westcoast's Avatar
Westcoast
Old 08-07-2020 | 03:56 PM
dmk2's Avatar
dmk2
I have noticed the same
Old 08-07-2020 | 04:45 PM
ForeverCar's Avatar
ForeverCar
I think it’s a good way to get to high oil temp to “burn” moisture if there’s any. Good feature.
Old 08-07-2020 | 08:02 PM
Larry Cable's Avatar
Larry Cable
+1!
Quick Reply: GT4/Spyder Driving Easy, low RPM = high oil temp, aggressive high RPM = low oil temp
