German configurator says its available till November and the word on the street is that it will be replaced by Shark Blue. Cannot answer the too late ? Talk to an SA to see if you can get one in the Q already with a build date before then maybe? Good luck MB will be a color for the ages.
I was reading some of the post and people were mentioning that Miami blue is no longer available to order? Is that true
you will need to find a dealer with an allocation for Sept or Oct, also remember you do not need to find a Ca dealer, you can use an out of state dealer and take delivery at the
Porsche Experience Center in L.A
From what I’m hearing, there will be a gap between blues. Shark blue will launch in 2021... when the 992 GT3 debuts.
Will Shark Blue be one of the $3,500 extra cost Special Colors, like Miami Blue? If that timing is correct I will miss the Shark Blue opportunity as my GT4's configuration locks in early November for a late January delivery.
