cost of servicing manual vs pdk?
Does anybody have any concrete information of how much it will cost to service and replace clutch vs servicing pdk? How long does the pdk generally last in Porsches before needing service and other than failure, would the pdk ever need to be replaced? I assume the wear in pdk is at a much lower rate since it's all controlled by computer vs manual transmission has the variable of human control and engagement.
PDK failures are extremely rare on the third generation of PDK (used on 982 and 991.2). Officially, the fluid should be changed out every 180,000 km or 12 years, though for peace of mind I’d prefer to change it at half that interval. The wet clutches should last the life of the car (300k km or more, maybe a million+ km, though nobody has driven one that far). I’ve never heard of worn out PDK clutches on the newer generation of the transmission either. My experience with wet clutches in heavy machinery suggests they can be extremely durable if properly controlled. On wheel loaders, they typically last 20,000 hours of operation, where the transmission is constantly shifting and changing directions every few seconds.
Unless you get unlucky and something fails catastrophically, you’d likely have gone through many clutch replacements and even synchro-mesh replacement on a manual transmission before a PDK wears out.
PDK-S service is required much more frequently than numbers kindly provided in post above for PDK-S in GT3, maybe standard PDK is more resilient? PDK-S gets Clutch fluid at 48,000 miles and transmission oil at 96,000 miles.
Underblu (07-02-2020)
As GrantG says, there is no scheduled maintenance for the manual (most people will never put 100k miles on their Porsche). And a clutch should last you the life of the car unless you beat the crap out of it or just don’t know how to drive a manual (or perhaps Use your car to teach your kid how to drive one).
In GT3, the manual gearbox has to be serviced only to change its oil and this has to happen every 96,000 miles (I couldn't believe it - I assume it's same or similar for GT4). If you drive competently, it is unlikely that you'd need to replace the clutch within this timeframe.
On 987.2 i've changed oils in pdk and dif (not including oil filter/gearbox sump) - it wasn't cheap but not crazy. I can't imagine stretch oils change to 180,000 km - i did the change at ~65,000 km and the pdk felt so much better after this.
Changing clutch and flywheel on manual car will be much more expensive.
