Tire pressure question
Guys,
How much you care about propper pressure? I know its 2/2.3 but what is optimal when you are actually ride ? What is too high too low?
also what morning is colder, than pressure drop by 0.2 for example, if noon is high like 30+ decrees is again higher by 0.1-0.2
are you trying to setup pressure right or not?
thank you
thank you
Hmm, nobody is willing to share hot tires pressure?
You are using bar so you must not be in the USA. What does your country specific owner's manual recommend. Start there and fine tune afterwards.
Roarke (07-04-2020)
The optimal tire pressure also might be different between Cup2 and Dunlops.
