ESC+TC off but still cutting power on hard launch?
I’ve noticed that my car is still electronically interfering by cutting power when I try launch the car hard, despite ESC+TC being switched completely off?
This happens regardless if I use the launch control function or not.
The cars wheels start spinning and then you can feel the power gets cut very briefly before taking off.
Does anyone know why this is happening and how the issue can be fixed? If I have ESC+TC completely off I want absolutely no electronic nannying or interference!
When I first tried this the car had under 1000 km’s on the clock, so I thought it may be a built-in safety feature or something, but I’ve subsequently tried it after passing the 1000 km point and it’s still doing the same thing.
Thanks in advance for any assistance...
Any bogging on launch is either built in torque protection in first gear, or is due to the amount of traction that the wheels have (big rear tires). You mostly see this effect in AWD cars without launch control: instantly shifting torque to 4 wheels of traction and your engine is going to bog down because there's not enough torque to spin the wheels that quickly.
These cars DO have launch control. This has been discussed previously in the forums and I posted a page from the manual here. As also stated previously in the forums, I have tried a couple of hard starts with PSM+TC off. I over-revved it and left some liquorice behind. The confectionary delivery only ceased when I backed off the throttle a little -- are you sure you did not do this instinctively?
If you really want to test your theory of engine cut-off, try to do some sustained burnouts on purpose and film the results for us. I have no interest in cooking my tyres further to answer this question.
According to page 216 of the manual, you should leave TCS on for launch control
DFW01TT (06-24-2020)
Isn't the point of launch control to moderate slip and traction to optimize the acceleration? If the rear wheels are spinning the control is going to adjust power delivery until you have traction. Are you trying to do a burn out or just launch without computer assistance?
Anyone in this thread: Is there text appearing on the PCM saying "Launch Control Activated"? If not, then it does not have launch control.
thedoctor (06-24-2020)
