718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
The Official White and Carrara White Metallic Color Thread
Old 02-12-2023, 12:50 PM
  #451
dmboone25
dmboone25's Avatar
Originally Posted by Lucifer
Can you post some unfiltered photos with the roof close? Preferably in direct sun light
Sure thing - here you go.
This is the standard iPhone 13 Pro photo setting, with no filters that I know of.
GTS992SA (04-30-2023)
Old 02-12-2023, 01:09 PM
  #452
Lucifer
Lucifer's Avatar
Thank you, I appreciate it. The more I see this color, the more I lean toward it. And, assuming this is the same CWM that is on the Taycan, photos really don't do it justice.
What's your opinion on brake dust with this color? Do you find it a problem?
dmboone25 (02-12-2023)
Old 02-12-2023, 01:14 PM
  #453
dmboone25
dmboone25's Avatar
Originally Posted by IndigoInkTaco
Maybe I skimmed over it, but are there any pics of White next to a Carrara White ? To see the difference, side by side? Or is it so subtle that it's not really noticeable?
I would say that CWM looks a bit cooler, with slight blue undertones. The pure white is a bit warmer, if that makes sense.
if you get up on CWM, you can see the metallic flakes, but it’s a subtle effect in my opinion, at least as opposed to other metallic colors.
I feel like the difference really stands out for CWM in the morning before sunrise, or just after sunset. That’s when the cool / blueish effect is most apparent to me.
Old 02-12-2023, 01:20 PM
  #454
dmboone25
dmboone25's Avatar
I really like it - it’s beautiful and bright in the sun, but has more character and differentiation in lower light. Like I mentioned in my other reply, that’s when the coolness or blueish hints come out, which I personally like a lot.
I put Gyeon Cancoat on my wheels a couple of times a year, and that seems to help with brake dust. The platinum wheels also help with that - if you get a good tire shine, you won’t see sling onto the paint, and I’m not sure I’ve ever seen brake dust make it’s way to the fenders or doors. I use Adam’s Graphene Tire Dressing and it’s great without slinging. I DO wash at least one a week, though.
The following 2 users liked this post by dmboone25:
BoxKing (02-12-2023), Lucifer (02-12-2023)
Old 02-12-2023, 01:27 PM
  #455
Lucifer
Lucifer's Avatar
Thank you. I honestly never cared about dirty wheels, I was only worried about the dust sticking on the white fenders
Old 02-12-2023, 01:42 PM
  #456
dmboone25
dmboone25's Avatar
I’ve never noticed any brake dust on the paint, but mine is washed regularly.
Old 02-12-2023, 02:04 PM
  #457
BoxKing
BoxKing's Avatar
Seems like you take pretty good all around care of your CWM
One of the many things I recently purchased in the care line up is DLUX by Carpro. I’ll be applying 2 coats to the wheels/calipers, and all the black plastic bits. I recently decided to against my feelings about adding ceramic over my soon to be full PPF, and bought HALO Ceramic to go over the PPF, so I doubt I will have much iron fallout from brake dust either.. I also plan to do a weekly maintenance wash. Every single tire dressing out there will sling onto your paint work if one applies too much. I currently have a 3yr old bottle of CarPro Pearl thats basically finished, so I will be on the hunt for its replacement. How do you like the Adam’s product; what’s the finish look like (matte/gloss?), how long is the protection lasting you?
Old 02-12-2023, 02:29 PM
  #458
dmboone25
dmboone25's Avatar
I would say the Adam’s graphene tire dressing is sort of in the middle. More glossy than a matte finish, but not a ton of “bling” if that make sense. My brother in law uses Pearl and I’d say it’s a little more wet looking than that. If you look at my pictures from earlier today in this thread, the tires have the Adam’s graphene dressing on them, and it was applied last night.
I typically wash my cars in the evening (that’s when I have shade in my driveway), so when I blow all the water off the car, apply my topper to the paint / glass, and add my tire dressing, it has all night to settle into the rubber. I really don’t see much sling using this approach. Also, If you can clean the tires well before the first application, then you won’t have to reapply all the time. Because it really seems to stick.
The water consistently beads off the tires, even if it’s been a few weeks since the last application. And it retains that darker look over a couple of weeks, but loses some of the “wetness” or bling look.
EDIT - having a coating on the wheels really helps. I’ve used CanCoat and MOHS Evo on my wheels with good success.
Old 02-12-2023, 02:38 PM
  #459
TRAKCAR
TRAKCAR's Avatar
Received 1,689 Likes on 786 Posts
Still look good
The following 3 users liked this post by TRAKCAR:
FRIZ (05-03-2023), GTS992SA (05-28-2023), JAhmed (02-12-2023)
Old 03-05-2023, 06:49 PM
  #460
Lucifer
Lucifer's Avatar
Finally managed to see CWM on a 718 in real life, also was lucky enough to check it in direct sunlight.
There is no way this is the same CWM that is used on the Taycan.
They look completely different.
Old 04-30-2023, 12:45 PM
  #461
BlackCobra
BlackCobra's Avatar
To me there is nothing like a white porsche. my 981 GT4 was white with black and red accidents and was perfection. Going for a GTS in something else this time but white is one of my top picks for these cars.
The following 2 users liked this post by BlackCobra:
BoxKing (04-30-2023), GTS992SA (04-30-2023)
Old 04-30-2023, 11:14 PM
  #462
Jeff Jones
Jeff Jones's Avatar
Received 1,762 Likes on 692 Posts
The following 2 users liked this post by Jeff Jones:
GTS992SA (05-28-2023), Home Run (05-19-2023)
Old 05-19-2023, 10:08 AM
  #463
911Jetta
911Jetta's Avatar
Trying to redeem myself for my grave error... lol... posting to the "official" white thread from now on.
The following 5 users liked this post by 911Jetta:
Bodibedo (05-20-2023), BoxKing (05-19-2023), Boxtop (05-20-2023), Denny Swift (05-28-2023), GTS992SA (05-28-2023)
Old 05-27-2023, 05:52 PM
  #464
BoxKing
BoxKing's Avatar
CWM
The following 2 users liked this post by BoxKing:
GTS992SA (05-28-2023), StilettoPat (05-27-2023)
Old 05-28-2023, 05:00 PM
  #465
Denny Swift
Denny Swift's Avatar
Received 1,631 Likes on 686 Posts
BoxKing (05-28-2023)
Quick Reply: The Official White and Carrara White Metallic Color Thread
