Pic of GT Silver with Base Headlights?
#31
Personally prefer LED headlamps on all my cars for better visibility at night. On the Porsche, its the 4 dot drl which looks nice and modern for me... but HID’s are fine too... just not the base halogens for an already expensive car. 😊
#32
I reluctantly specced PDLS because I want brighter lights that can follow curves. Almost went with base because I hate the headlamp washer warts.
Has anyone found a way to remove the warts? Can you remove the washer assembly and replace the protruding nozzles with flat / flush inserts?
#33
theEnd (05-01-2020)
#37
Do the LEDs give superior illumination over the Zenon HIDs I chose with my GTS 4.0? Can you actually see further down the road with them? I'd love to see some proof of that.
#38
I haven't driven a 718 at night with either headlight configuration, but my Cayenne has the PDLS+ LEDs which I've owned for over 70,000 miles. I've also driven many, many other Cayennes with the Xenons (friends cars, service loaners) and I can tell you the LED is a MASSIVE difference. For that reason alone, LED was a "must" for my Spyder build. In fact if I had to give up every option but one? LEDs would be the one I would keep.
The following 2 users liked this post by daaa nope:
Goodwood (03-05-2021),
RennSportV8 (12-31-2023)
