GPF part # for USA and ROW
#46
@TXshaggy do you have the measurement for the 3 nuts at the header end, I am pretty sure they are 8mm nuts but I am looking for the overall diameter of the integrated washer?
They 'may' be identical in dimension to the 5 nuts at the GPF end, trying to verify this...
#47
INCLUDED COMPONENTS
o (1) Driver Side Over Axle Pipe
o (1) Passenger Side Over Axle Pipe o (10) M8 x 1.25 x 30mm Bolts (13mm) o (20) M8 Washers
o (10) M8 Locking Nuts (13mm)
You reuse the header hardware.
I had a specialty shop install mine; so unsure of the header hardware.
I could put a ruler on the hole diameter tomorrow if that’d help.
Suspect it’s similar to the GPF hardware.
#48
They remind me of this. Could be a 2020 thing......
I’ve read speculation that Porsche makes them all (relatively speaking) the same so the engine mapping and back pressure is the same across the engines. Is anyone worried that just removing these messes with those two parameters? I don’t know enough about “engine mapping and back pressure” to really have an opinion, but I am wondering about taking out a middle component between to other designed pieces (header and muffler).
#49
UncleDude (12-02-2020)
#50
Here are the Soul Parts Hardware for the GPF end:
INCLUDED COMPONENTS
INCLUDED COMPONENTS
#51
We discussed the install and loosening the back exhaust, but he said the studs backed right out per the Soul instructions.
Now that I’ve got mine on; would recommend it to anyone looking for more. Believe for all but the most hardcore GPF delete will achieve excellent results without further mods.
0-Day (12-02-2020)
#53
0-Day (12-03-2020)
#54
Admire your effort to support your local shop (Maybe it was the yellow!). For comparison, if anyone interested, a larger local shop in SoCal quoted $400 for OAP and Cargraphic Valve Controller. I also believe a smaller shop would do them for even less (Not trying to squeeze the shops, but these were their stated pricing when asked). Also other posters I think have said the OAP job was done in under 2 hours.
#55
As for just the OAP and if you are expecting them to fabricate mounts for the vacuum lines I would say 3 hours, in two hours those lines would be still flapping in the breeze...
#56
Does the car need to be reprogrammed to accept a GPF delete & eliminate the possibility of throwing a code?
#57
The following 2 users liked this post by TXshaggy:
smiles11 (12-03-2020),
Soul Performance (12-04-2020)
