718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Collection today
Old 03-20-2020, 05:14 PM
SpyderSwede
SpyderSwede's Avatar
Default Collection today
Just collected my Gentian blue Spyder today , the roof is very difficult to close it takes two people pushing the roof forwards to get the closing hook to activate, is this normal, maybe it will stretch over time ?
The other thing I have noticed, if you try changing gear with the engine off it sounds like an tin can ..... Is this normal or is the linkage hitting a shield or something.
otherwise pleased with the car , especially when the valves open at 4000 rpm , unfortunately still limited to 4500 but can't wait to get it run in 😀😀😀
The following 2 users liked this post by SpyderSwede:
718GT4.0 (03-21-2020), ISPYA718 (03-21-2020)
Popular Reply
03-21-2020, 07:09 PM
SpyderSwede
Originally Posted by Pokerhobo
No pictures?!
Picture 😉
Old 03-21-2020, 06:21 PM
Mash
Mash's Avatar
All normal!
The gearshift sounds are an indication of how well built and raw the gearbox is. You hear the mechanical stuff, which is pure bliss.
with regards to the roof, I faced the same exact issue with a brand New 718 Spyder sitting at the showroom floor, not sure if I was closing it wrong, or like you mentioned it will loosen up after time.
Old 03-21-2020, 06:41 PM
masti99
masti99's Avatar
Congrats, enjoy in good health!
SpyderSwede (03-21-2020)
Old 03-21-2020, 07:03 PM
718GT4.0
User
718GT4.0's Avatar
Congrats!
Roof closure is somewhat normal, just leave it open - problem solved.
Or rewatch some of the Carfection videos on YT showing them putting it on, I don't recall they had a massive issue closing / opening though.
Old 03-21-2020, 07:04 PM
Pokerhobo
Pokerhobo's Avatar
No pictures?!
Old 03-21-2020, 07:09 PM
SpyderSwede
No pictures?!
Picture 😉
The following 14 users liked this post by SpyderSwede:
2XIPA (03-22-2020), 718GT4.0 (03-22-2020), abarthguy (03-22-2020), AlexCeres (03-21-2020), Antipodean (03-22-2020), arek (03-21-2020), CDACH (03-22-2020), Dbridges (03-21-2020), DFW01TT (03-22-2020), ISPYA718 (03-21-2020), JSF101 (03-21-2020), Pokerhobo (03-22-2020), triode (03-22-2020), Underblu (03-22-2020) and 9 others liked this post. (Show less...)
Old 03-21-2020, 07:16 PM
SpyderSwede
Originally Posted by 718GT4.0
Congrats!
Roof closure is somewhat normal, just leave it open - problem solved. 9o
Well I only put the roof up when it goes in the garage , 5C but sunny today in Sweden 😀 found out tonight that if you pull the roof shut and the closing hook activates but misses the pocket on the windscreen frame the only way to get it into the open position is to drop the roof and close the rear deck then the hook will move retracted position, unless anyone knows different???
Mash
Mash's Avatar
Congrats
Old 03-21-2020, 10:42 PM
arek
arek's Avatar
When I was picking up mine, I was informed that it might be difficult to close the roof initially and that it should get easier with time. Mine is not too bad though, I can definitely do it alone. Make sure you’re leaving the rear deck unlocked (place it down but don’t push it to lock) before closing the hook.
I was also advised not to leave the roof down for extended time (like days). Basically whenever you park in your garage, always close the roof. This way the material can stretch a little.
Also, congrats!
Old 03-22-2020, 12:18 AM
Underblu
Underblu's Avatar
a little tip, i used to struggle with my roof to. Use your fingers to center the hook within opening and then press the close button, it shouldn’t take that much effort. if the hook is centered properly it will close without issue.
Old 03-22-2020, 01:35 AM
Antipodean
Antipodean's Avatar
Tips for closing 718 Spyder roof:
1. Use the internal handles. They are about 30cm back from the leading edge of the roof. There is one on each side, about level with the sun visors. One hand stays on a handle, the other hand stays on the "roof close' button. Use the handle and pull the roof as close to the final position as you can manage. Keep pulling forward / down while pressing the button, you will help the motorised hook and it will help you.
2. If the hook missed, keep holding the close button and the hook will open up again for a second try. But the hook will never miss if you use the roof handles.
3. If you have arthritic shoulders or weak arms, this may not be the car for you.
Edit:
The correct sequence for closing is: close rear decklid fully, attach winglets, and only then do the "final closing" steps above. I would not recommend closing decklid as the final step. I would also not recommend grabbing the motorised hook, especially during the actuation of the hook (simply for the safety of your fingers).
SpyderSwede (03-22-2020)
Old 03-22-2020, 10:31 AM
orclean1
orclean1's Avatar
Car looks amazing enjoy breaking her in
Old 03-22-2020, 10:44 AM
718GT4.0
User
718GT4.0's Avatar
Picture 😉
Stunning
Old 03-22-2020, 10:59 AM
pitt911
pitt911's Avatar
Received 1,050 Likes on 600 Posts
great looking car
I had a 981 Spyder with the same roof for two years , it will get easier with time , either you get better at it or the cloth stretches a little bit , not sure
but overall , still an annoyance enough for me , that when they announced the 4.0 GTS with automatic roof , decided against the Spyder . I know there are differences , but to me not big enough at this time ..
Old 03-22-2020, 03:43 PM
Westcoast
Westcoast's Avatar
Received 4,739 Likes on 2,756 Posts
Picture 😉
So they let you take the car home before the paint was dry!?
Simply stunning shade of blue...
Congrats!
Quick Reply: Collection today
