718 Forum 982 (718) 2016-Current Discussions about 718 Boxster Cayman Variants
Stuck radiator fans - need help
Old Apr 23, 2025 | 01:00 PM
Simon d.'s Avatar
Simon d.
Default Stuck radiator fans - need help
Hey everyone. Need some help and to see if anyone else here has had the same problem. I recently had a yellow check engine light come on and the dealer found that my radiator fans were jammed with small pebbles. The backstroy here is that I live on a dirt road, and the super sticky P Zeros grab loose stones when I drive on it and throw them around the wheelwell. The problem is that there are vents between the radiators and the wheel wells and the stones thrown around end up in the radiator cowl and jam. Both we jammed at 5000km on my 718 new GTS.
I could drive slower so they don’t get thrown around. But I drive it at under 5kph as-is and still hear stones getting thrown around the wheel well. One idea I have is to get a body shop to attach screens over the slits, allowing air to pass through but not stones. Another is replace the tires with less sticky rubber, like MPS4 A/S.
Any other ideas, or anyone else have this?
Old Apr 23, 2025 | 04:42 PM
BondJ's Avatar
BondJ
There are any number of firms supplying custom fit mesh covers for the rear quarter vents. You can even buy it on a roll and cut it yourself. A quick Google search will identify a retailer in your part of the world.
Don’t bother changing the rubber. The Pirelli’s are no more sticky than any other comparable road tyre
Old Apr 23, 2025 | 10:05 PM
ReidMct's Avatar
ReidMct
Pavement.
Old Apr 25, 2025 | 11:58 AM
Simon d.'s Avatar
Simon d.
Actually, it’s the radiators in the front that are the problem.
Old Apr 25, 2025 | 12:11 PM
BondJ's Avatar
BondJ
Understood. Same applies. Lots of vent covers available for the front 👌
Old Apr 25, 2025 | 12:26 PM
Spyerx's Avatar
Spyerx
get some aluminum mesh that is smaller than the current grids and rivet to the liner. You can even use something like this, though there are companies that sell finer mesh grill screens too, for a lot more money:
https://www.homedepot.com/p/Amerimax...60X2/205207064
You can search on amazon for lots of examples too. Stay away from 'motorsports' suppliers, its the same material at 10x the price :-)
Old Apr 26, 2025 | 02:26 PM
maschinetheist's Avatar
maschinetheist
i can confirm that HD gutter mesh works well, a number of us run em at the track.
this one is also commonly used and referenced here:
Amazon Amazon
no shame in saving $300
Old Apr 29, 2025 | 02:17 PM
Spyerx's Avatar
Spyerx
this one is also commonly used and referenced here: https://www.amazon.com/gp/aw/d/B08PB...b_b_asin_title
I did this mod a decade ago on my 997RS, that car has a huge opening in the fender liner with no screen at all, at least porsche now puts some type of protection in the liner but its still not great. On the 997 cars it was really common a rock would get thrown into the back of the radiator on track. I used that HD screen and used some zip ties and it's still there, and never had an issue, the upside is less rubber pebbles in the radiator space too.
