718 Forum 982 (718) 2016-Current Discussions about 718 Boxster Cayman Variants
QuickJack for the 718
Old 02-05-2024, 11:41 AM
jean458
jean458's Avatar
Default QuickJack for the 718
Hello,
Has anyone lift the 718 with a quickJack 7000-TLX?
I have a 718 Spyder and also a Macan. I would like to lift both cars, but I want to be sure the 7000-TLX will not be too long for the 718 Spyder.
Old 02-05-2024, 01:30 PM
F1-DNA
F1-DNA's Avatar
I would bet the 7000-TLX is too long for the 718. The standard just fits wheelbase as it is.
Old 02-05-2024, 01:44 PM
maschinetheist
maschinetheist's Avatar
Can you use standard 5000 and then get the frame extensions for longer cars (if really needed) ? Lift capacity of 5000 should be plenty for a Macan.
Old 02-05-2024, 01:50 PM
F1-DNA
F1-DNA's Avatar
This sounds like the smartest move. Here is a pic of my 5000tl standard sized. You have to position the QJ a little more towards the rear because of that jack point location.
Old 02-05-2024, 04:30 PM
jean458
jean458's Avatar
I would rather buy the 7000-TL which is the same length as the 5000-TL but can handle more weigh.
I'm am just wondering if I buy the 7000-TL, it looks like a bit short to lift a Macan
Old 02-05-2024, 06:12 PM
F1-DNA
F1-DNA's Avatar
If you don't want to store the QJ's under the car while not in use then the 7000 is a smart move.
Old 02-06-2024, 01:46 AM
RZT5
RZT5's Avatar
The normal TL seems to be pushing the length limit for the 718. I would think the TL would be fine for the Macan too...
Old 02-06-2024, 08:59 AM
jean458
jean458's Avatar
ok thanks for the pics , then I will go with the 7000-TL and if one day I have a bigger car I'll buy the extension.
Old 02-06-2024, 10:16 AM
GTSilver944
GTSilver944's Avatar
7000 is heavy to lift/move. Macan is sub 5000lbs.
Old 02-06-2024, 10:20 AM
jean458
jean458's Avatar
I think it will be okay with the wheels modification. Although I will use the quickjack 10 times in a year only.
It's just if for any reason I decide to buy the Macan EV in 3 years, I would rather not to buy a new set of quickjack
Old 02-06-2024, 12:19 PM
aclicky
aclicky's Avatar
Does the car actually sit on the "adapter blocks" while on the quick jack or is there a special adapter required. Cheers, M
Old 02-06-2024, 12:48 PM
F1-DNA
F1-DNA's Avatar
The blocks that come with the QJ work great, no adapter needed.
The following 2 users liked this post by F1-DNA:
aclicky (02-06-2024), Haros (03-06-2024)
Old 02-06-2024, 05:00 PM
jean458
jean458's Avatar
btw the 7000-TL will fit the 718 but if I want to lift my Macan, the maximum lift point spread is 160cm (63").
It means the lift points will not be fully standing on the pads because the maximum lift point spread of the 7000-TL is 152cm (60")
I would like to hear someone lifting a 718 and a Macan with the same quickjack. 🙂
Old 02-07-2024, 03:41 AM
CurryPuff
CurryPuff's Avatar
I have a 7000TL. The fit is great and I use the smaller of the supplied blocks. Using the smaller of the supplied blocks, I think there is only 2-3 cm of space to position them around.
This is what they look like at full extension. I used to change the OAPs on my GT4 and it made life so much easier.
However, they are HEAVY to move. I got them to lift my GT4 and a X3 M40i (haven't tried it on this one yet).
Old 02-08-2024, 11:39 AM
sirringo
sirringo's Avatar
The TLX fits fine. I wanted the flexibility to lift various cars, including my Evo, so the extended model was a must for me. If you position it properly there are zero issues; at worst the front tires will contact the frame as it comes up, but it's not dramatic - and that's avoidable if you move the frames back a touch.
I agree the 7000 is overkill FWIW, even for the Macan. The 5000 are 85lb or so per ramp so they're non-zero effort to move around (I have mine vertically wall mounted and lift them off then roll into place). I'm assuming the 7000 are heavier. My other points to know:
-If yours will live on the floor, you can install small spherical wheels underneath to make it easy to roll them around while flat on the ground - however the clearance to the 718 lift points, depending on your ride height, will be minimal at that point:
-I put a jack stand underneath each frame just for backup, but I've had no issues at all with operating the QJs and am quite happy with them
Quick Reply: QuickJack for the 718
