718 Forum 982 (718) 2016-Current Discussions about 718 Boxster Cayman Variants
I have $80k. Base with some performance stuff or bare bones S?
Old 06-12-2023, 03:03 PM
timothymoffat
timothymoffat's Avatar
Received 1,011 Likes on 449 Posts
Originally Posted by lion shf
also my fav but they’re hens teeth
They do show up time to time. Be patient for the right car, whatever it is you'll know when it pops up.
Old 06-12-2023, 03:14 PM
manifold danger
manifold danger's Avatar
Received 1,134 Likes on 639 Posts
I’m glad you brought that up. Is an 18/19 the same car as a 2021+? I guess my question is if a base 2021 is a better car than a 2019 S/GTS mileage and condition being equal. I’m not concerned with resale, I keep cars a long time. I love the 2.5 GTS but don’t love it’s s bit older than the base cars I can buy. Non issue?
No tangible difference between a 18/19 GTS and 2021+ S cars, but as you're probably aware the 2021+ GTS got the 4.0 N/A flat 6.
That said, the 2.5 GTS is nearly identical to the 4.0 GTS in all but engine.
Old 06-12-2023, 05:22 PM
TXshaggy
TXshaggy's Avatar
Received 3,438 Likes on 1,978 Posts
The current gen of Boxster/Cayman came out in 2017.
The base and S are essentially the same through now. Some small equipment changes in the connect or Apple CarPlay or other small option differences.
GTS has two different trims in 4 and 6 cylinder.
Ts were ordered in limited numbers.
Pick a trim, and then get the newest best conditioned car you can.
I’d buy from a dealer that included CPO.
lion shf (06-12-2023)
Old 06-12-2023, 08:44 PM
lion shf
lion shf's Avatar
Did CPO on my TT, voided it in a few months
Old 06-12-2023, 08:57 PM
cbracerx
cbracerx's Avatar
With that budget the -20 GTS is the “Best Buy”
Old 06-12-2023, 09:44 PM
lion shf
lion shf's Avatar
They are 105.
Old 06-12-2023, 10:01 PM
TXshaggy
TXshaggy's Avatar
20 GTS? Don’t think there was a MY20 GTS.
The 4.0L GTS started production in the fall of 2020 as a MY21.
You won’t get one for $80K.
Old 06-12-2023, 10:06 PM
GregWormald
GregWormald's Avatar
The performance difference is in two areas where the larger engine makes a difference: at low rpm below the turbo comes on strong, and at high speeds where you are in license-losing territory.
The options can make a difference whenever you're driving.
Your choice—buy the one you like best.
Old 06-13-2023, 12:44 PM
cbracerx
cbracerx's Avatar
My comment was to recommend purchase of a pre '21 GTS which is the 2.5 liter (-20 notation is models up to that year. 20- would be 20 and newer). I'm quite aware of the cost of the 4.0 GTS
Old 06-13-2023, 02:56 PM
Zhao
Zhao's Avatar
Received 1,726 Likes on 948 Posts
Originally Posted by manifold danger
The only people that will tell you to get a base are people who bought a base.
Nah, I'd say go base. The base is quick enough to have fun. Suspension + a LSD in a base would be good bang for buck.
Old 06-13-2023, 06:03 PM
lion shf
lion shf's Avatar
id put lsd 3rd behind PASM and SC. Do I have them reversed?
Old 06-13-2023, 08:55 PM
Zhao
Zhao's Avatar
No one needs a LSD, but it does enrage me to not have a LSD at the limit. 1 tire fire on corner exit is such a limp wristed handling characteristic it's an instant turn off for me. Only like maybe 3-5% of Cayman S owners get PTV so it's a super rare option, but for me it was a must have. You can get an aftermarket LSD cheap from Deman though relatively cheap.
Suspension for the street isn't really necessary but it can help the feel. Stock stuff is good but designed as a compromise to do nothing specifically the best it can be done so there is no trade off with doing something else like ride comfort terribly. For track though it's pretty much necessary for additional adjustment since the factory camber range is really poor so with more negative camber the tire will make better contact with the pavement in the corners. Anytime you can get the tire to keep contact with the pavement when it's bouncing around over bumps is an advantage also. Spring rates, sway bars, redoing suspension, being able to adjust the height of the car can help with the car maintaining as much contact patch as possible too.
You can modify a street car to handle better, but IMO you shouldn't do it yourself or trust a 'performance' shop to do it either. Besides swapping in a set of kw coilovers or whatever, aynone trying to re-engineer the car to handle better by mucking with everything is almost guaranteed to turn it into something far worse than stock. The worst handling cars I instruct are consistently the street cars turned into 'track cars' with way too many suspension mods, all setup by the owner or someone who doesn't know what htey're doing to correct a problem the driver has that only needs to be corrected with driver skill, not modifying the car (such as it needs more rotation!). WHat happens is people with no driver skills can't figure out how to rotate a car, and they learn the car (all cars are setup to understeer) is setup to understeer slightly, that they modify the car for maximum rotation! These cars often become undrivable and terrifying on the track. I can think of one specifically that I was setup so bad that I knew if I came anywhere near the edge it was going to want to loop itself. Slowest car I ever drove on teh track because of that, slower than a 2000ish automatic inline 4 accord i once got for a student. There are fellow road racers that have cars setup to over rotate even. These guys are usually backmarkers. Any car can be rotated with driver skill so it's not necessary to modify a car to achieve that result (although changing the alignment settings to remove the -1.5 degrees camber some cars come with and giving it as much upfront as possible with 0.5 more positive camber in the rear than the front is usually a good recipe. if you can run -2 in the front, run -1.5 in the rear). Porsche spent a lot of money figuring otu how to make the suspension pretty decent, you can make it better fairly easily by doing a few things, but if you're going to muck with swaybars nad spring rates almost guaranteed it'll end up worse so I'd say don't do it.
But I am literally the worst person to ask about suspension setup for how many years I've been racing. I figure driver skill can over come a lot so I don't bother fine tuning anything I race beyond the bare minimum to get even tire wear.
If you want SC, it's not like you can add it later so you probably want to find one with it. It doesn't do anything in my GT4 except look pretty.
PASM goes out the window if you're going to change the suspension anyway, but if you're going to leave it stock, I'd want it, and it looks better too with the lower springs.
lion shf (06-13-2023)
Old 06-13-2023, 10:11 PM
lion shf
lion shf's Avatar
The S, GTS and T are attractive to me cause the 20mm PASM. If SC isn’t all that I won’t pass up a good car that doesn’t have it. Thx for your reply.
Old 06-13-2023, 11:03 PM
TXshaggy
TXshaggy's Avatar
If you’re looking for a PDK non GT 718 car you want SC…period.
Post above talking about SC and GT4 is a different conversation.
lion shf (06-14-2023)
Quick Reply: I have $80k. Base with some performance stuff or bare bones S?
