I used the bottom row in the passenger footwell for my 22 Spyder for my Escort MaxCam 360. The bottom row will give you switched power for when the vehicle is on. The 3rd row from the bottom is for constant power if you have a dash cam for parking mode if you wanted that.
Thanks for everyone's input..I waited to have a voltage meter to see which one I can safely be tapped into.
on GT4 2021 all fuses have constant voltage when the ignition is off except the third rows D 1, 2, 7 They do not get any voltage when the ignition is off. To me, it's a big no-no to tap into those since some link to Airbags, PASM, and DME. @Unstockpassenger footwell has constant voltage I guess it's different in GT4
I end up tapping into an unused fuse.
