PZeros and temperature ... ?
"Michelin Ultra-High Performance (UHP) Sport Summer tires use tread compounds that are optimized for maximum dry and damp grip in temperate conditions. As the temperature of the compound nears freezing, the grip level of the tire begins to degrade. Michelin does not recommend using UHP Sport Summer tires when tire temperatures drop below 40°F (5°C) or on snow and ice. At tire temperatures below 20°F (-7°C) Michelin UHP Sport Summer tires may develop surface cracks in the upper sidewall and tread area if flexed. Do not use, roll, or drop MICHELIN UHP Sport Summer tires with temperatures below 20°F (-7°C). If the tires have been cooled to 20°F (-7°C) or less, let them warm up in a heated space to at least 40°F (5°C) before being installed or moving a vehicle on which they are installed. Do not apply heat or blow heated air directly on the tires. Always inspect tires before use. Never use a tire with freeze cracks, breaks, or damage to the sidewall or tread."
Take it for what you will.
It is very true that the vast majority of drivers never get near the limits of grip… on dry, summer public roads.
You miss the point though. The point is that very unexpected things happen on public roads. Driving on tires in conditions when they will not have grip anything near their limits is something to be done when necessary not as a matter of course.
I don't need to drive in snow ... I have a Cayenne daily driver, and a F150 4x4 for that.
I just want to be able to drive the car when the roads are clear in winter without ruining the PZeros.
I don't need "winter dedicated" tires for the Boxster, just something I can
use for 3 months. Changing out the tires at Porsche is pretty easy. I've done that
previously with 911s.
You always seem to have a bone to pick with me on the forum and take a harsh tone. I think in temps between 35 and 45, most 400 TW tires can handle the situations you describe. I see many performance cars daily driven on 400s in my region (southeastern PA) all through the winter . Most of the drivers are probably blissfully unaware of the topic we're discussing. I think you're being a bit over the top about the risk of driving 400s between 35 and 45F on DRY roads. At this point, OP has information to make his own decision. I'll agree to disagree and not engage further.
With that said, I hope my delivery stays on schedule for early February 23’ - I will keep on the OEM tires on the car until Oct/Nov. 23’ - toss them in the trash, and wrap with Alpin 4’s for the winter months. Rinse and repeat each year: New summers each season, and Ill probably get 2-3 years out of the Alpin’s. My GT4 = My DD.
To answer your question… can you, yes, to some “DEGREE”, and caution (especially if its not your DD).
Lastly, if you live in an area that brines the roads during the winter seasons, you need to wait for a few heavy rains to drop late winter/early spring before they’re safe for pushing your cars to the limits, as the brine creates a slickness to the roads that’s invisible to the eye.
They should serve me well for that time .. and, run ~$800 delivered from Tire Rack. Having them
delivered to my dealer to install on OEM wheels in OEM size.
I've had a couple 911 Turbos / GTS in AWD on "summer tires" and found that the grip was just OK
on dry pavement at temps approaching 45 F, but I found the vehicle
responded in a surprising way even with AWD. And, the dealership service guy gave me the business
for driving the 911s in those temps with PZeros. Fortunately, I've always had a "winter car / truck" to augment my
drives. But, I'd like to drive the BGTS when ever I can. Expensive vehicle to park for 3 - 4 months IMO.
The Falken's should suit me well.
Thanks for the comments / recommendations.
Let us know how they feel after you road test them.
These might be a better option at that price point than the Alpin 4s
The BGTS is more fun to drive than any 911 I've owned.
And, the more I can be in the driver's seat ... the better.
Plenty of power / torque in all gears ... great fun factor.
My advice? Get a set of Micheline UHP PS4 All Season - and don't get them through your Porsche dealer, they won't go to bat for you with the manufacture. Regarding posts saying you're doing your car a disservice; My opinion is that overall, the UHP A/S will give you better performance outside of serious track days etc. If you live near mountainous areas where the temp can get very cold in spring and fall even though it's warm in town, and if you include rain days etc - you'll be out of your tire zone with summer tires as much as with A/S, but at least with A/S you won't wreck them or get yourself into a dangerous situation.
https://rennlist.com/forums/718-gts-...l#post18529891
Terry
