Sparks out the back - anyone ever seen?
Neither Porsche nor Nissan manufacturers catalytic converters. They obtain them from vendors. I have no doubt that Nissan cheaped out in many ways back in the early 2000s during the Carlos Ghosn years but it's not impossible for a defective part to find its way onto a Porsche or any car. Porsche had to replace GT4 and Spyder engines recently due to defective internal parts. No manufacturer is immune. What sets companies apart is how they handle the issue.
You worked at Nissan in the early 2000s? So was there an issue with catalytic converters breaking apart back then? Do you know if they caused engine failures as a result?
To answer your question about the cats: The story was, there was an ECU ignition timing error that caused the engine to knock so badly that it resulted in a damaged cat. The particles from that damage somehow found its way back into the engine and caused irreparable internal damage.
Not saying Porsche is immune to defective parts either, but I would figure their quality control is several levels higher than Nissan's. When you sit in a Porsche vs. Nissan, there is no doubt you're in a vehicle that's aiming for a higher product target than any Nissan.
ldamelio (10-25-2022)
