PIN Code?
PIN Code?
Does anyone know if the Cayman ICE system settings can be 'locked' with a PIN or password - mainly to stop annoying teenagers from changing the settings..? Thanks
Are you asking about In Car Entertainment? Or Internal Combustion Engine?
In either case, I think the answer is, no.
And I can't believe you allow annoying teenagers in your car unsupervised...
That's what I figured, but you can't be certain.
But in that case, I'm 99% certain the answer is no. I've done a lot of work and exploration on the PCM in my 2018 CB, including activating Nav and Android Auto. I did not see any facility to lock the settings down anywhere I explored.
I think if I had annoying teens messing with my car, there might be some nasty consequences.
You can’t lock the ice but you can lock your car…
