718 Forum 982 (718) 2016-Current Discussions about 718 Boxster Cayman Variants
CTEK another good neg. connection?
Old 01-28-2022, 04:01 PM
bcgreen
bcgreen's Avatar
Default CTEK another good neg. connection?
Is there another place to connect a CTEK eyelet other than the factory recommended negative post?
Positive connection is on the far passenger side and the negative connection is way over on the driver's side and this is stretching the
line so I can't make a tidy arrangement.
Old 01-29-2022, 12:10 AM
blue17
blue17's Avatar
Just cut the eyelet off and extend the wire (ring terminal, crimp connector, and short length of wire) so you can make a tidy arrangement. That's what I did.
Old 01-29-2022, 02:50 AM
Unstock
Unstock's Avatar
I have my official Porsche charger (same as CTEK) mounted on the wall and use a few CTEK extension cables to plug it into my passenger side cig lighter socket. Keeps the battery charged nicely. Its easy to plug and unplug from outside the car when I want to.
Old 01-29-2022, 08:27 AM
bcgreen
bcgreen's Avatar
Can't do that where I live. Gone for many months and unpredictable power outages require enlisting a neighbour to reset the units. Two cars have alligator clips, one is plugged into the cig. lighter. The one with cig. lighter needs to be hard wired.
Old 01-29-2022, 08:29 AM
bcgreen
bcgreen's Avatar
Simple enough, thanks.
Old 01-30-2022, 10:58 AM
Live Steam
Live Steam's Avatar
On my 991 I installed the negative to the nut for the retaining bar that spans across the top of the battery. The nut is under the wiper cover and against the firewall. So the wires neatly tuck in without being stretched across the bay. I pulled the quick connect up over the bay cover and it just rests on top for quick access.
Old 01-31-2022, 03:35 PM
Aronis
Aronis's Avatar
The mounting bolt for the strut. Get a nut the same thread. I just happened to have one the correct side LOL.
Mike
Old 01-31-2022, 03:38 PM
bcgreen
bcgreen's Avatar
Deleted
Old 01-31-2022, 03:47 PM
bcgreen
bcgreen's Avatar
Mike
That's doable. I am sure I have a nut that size after 55 yrs of collecting.
Old 01-31-2022, 05:59 PM
nineball
nineball's Avatar
i am probably breaking some porsche commandment but i just use the alligator clips directly on to the battery. been doing it that way for 5+ years now on this one and decades on my old 911.
Old 02-01-2022, 07:55 AM
Aronis
Aronis's Avatar
nothing wrong with that, just the negative terminal on newer cars has some circuitry that can be damaged from what others have posted, who the hell knows the true story.
Mike
Old 02-05-2022, 05:02 PM
aus
aus's Avatar
Can you plug the Porsche charger into the smoker package lighter to charge?
Old 02-05-2022, 05:10 PM
bcgreen
bcgreen's Avatar
You can, but as I have discovered, if you lose power then you need to reset it, whereas if it's connected to the battery it resets itself with no human intervention.
Old 02-05-2022, 06:23 PM
Unstock
Unstock's Avatar
haven’t tried that yet. I bought a few CTEK extension cables that I use to reach my cig lighter port in the passenger footwell. A male and female cig lighter adaptor and the 8’ foot extension cable. I’m able to reach my port easily.
Old 02-05-2022, 06:34 PM
TXshaggy
TXshaggy's Avatar
Received 3,831 Likes on 2,163 Posts
Yes, of course and the easiest.
Quick Reply: CTEK another good neg. connection?
