718 GTS rear low control arms
Hello! Want to make 3.0 camber on rear axle. Which rear lower control arms I should to buy? 997 GT3 front lower control arms will fit or not? Any additional parts I should to buy? Thanks
You'll also need adjustable toe links
Boba_kz (10-01-2021)
I don't think the GTS has adjustable LCAs, only GT4 models. You will need either adjustable camber plates and/or LCAs to achieve more than -2 deg rear camber.
I have the RSS Tarmac Series LCAs and adjustable camber plates and have maybe 1mm shim with -3deg rear camber so most adjustment is on the camber plates. Although my car is also lowered so that also adds a bit of camber. You'll also need the adjustable rear toe arms which RSS also sell. But lots of good options like Tarret, Elephant Racing, SPL, etc., or even regular OEM GT3 LCAs if you don't want the monoball.
Here's the kit I bought:
https://rennlist.com/forums/718-foru...arms-lcas.html
Rear camber is limited by the Toe Links. Change those for the Tarrett ones and then adj your camber. IF that isn't enough then you can add the split rear control arms. You will need to change the Toe Links in either scenario..
Peter
