That little piece is part of the cup holder assembly so you would need to remove the longer trim piece directly to the right and then remove the cup holders. When swapping my DB Carbon assembly in I used the photos and comments from this thread as a reference.
I don't know that the little section can be easily removed (if at all). It's connected to the cup holder assembly with a long rod which doesn't look to be removable.
Thanks, I think I will work on it in the car! I have a smooth finish emblem I want to put in its place and I thought it would be easier to do in the house if I could pop it out.
