718 Forum 982 (718) 2016-Current Discussions about 718 Boxster Cayman Variants
Front and Rear License Plate (my solution)
Old Sep 5, 2021 | 01:53 AM
edub's Avatar
edub
Default Front and Rear License Plate (my solution)
I am pretty surprised that Porsche offers you a self tapping screw as a 'solution' to mounting the license plate. It's neither pretty, nor durable a solution.
After researching better ways, I thought I'd post what I ended up doing in hopes it makes it easier for others to solve their own situation.
Front Plate - As much as the price pains me, the Platypus solution is clearly the best. https://www.cravenspeed.com/front-li...he-718-cayman/
They are also sold on Amazon, I was lucky enough to find a returned one and picked it up for half price.
The Platypus installs in the front tow point, so you can remove it later without any lasting effects. You need a allen wrench to mount the license plate to the backing plate. The US GT4 doesn't come with front parking sensors, so I can't say whether this would interfere with them, but I doubt it as the plate is not obstructing any of the sensor cutouts on my car.
Viewed from drivers side, parallel with front bumper
Rear Plate
This US car came with 4 dimples where the license plate screws should go, so the hardest part is done for you. Since the rear plate may come off for track days and access to the tow point, using self tapping screws was off the table as that would ultimately wear out.
I went with rivet nuts, which are handy little rivets with a threaded interior that expand in place, locking the threads from spinning when you tighten them.
You can purchase this kit You can purchase this kit
, or source your own to install them yourself. I used 10-32 but M5 or M6 sized rivet nuts would likely work as well. You'll need to purchase some stainless machine screws in metric or standard threading for the size rivet nut you end up with. (I used 10-32 size, 3/4" length machine screws.
This search will find similar This search will find similar
A rivet nut
You will need a drill bit of appropriate size, and a drill. I tapped off the points where I was going to drill but the plastic cuts cleanly and its probably not necessary.
Essentially you just drill your pilot holes for the rivet nut, pop the rivet nut on your installer tool, crimp the nut in place and then install your license plate.
Rivet nut (compressed already) on the installation tool
detail of what a compressed rivet nut looks like. The expanding walls both secure the nut from spinning and lock the outer lip and inner lip against the bumper material.
Installed rivet nut. You can see the interior threads ready to receive a machine screw.
Access to the rear tow hook is available by removing the license plate (something I would have done for a track day)
Old Sep 5, 2021 | 08:47 AM
Aronis's Avatar
Aronis
I'd rather hot glue the plate to my front window with extra scotch tape than do the off center thing....
Mike
Old Sep 5, 2021 | 10:54 AM
slilley's Avatar
slilley
Thanks @edub for the write up! I don't have to deal with the front plate (thankfully), but I'm planning on using Tom's Car Pokes ABS-milled mount for the rear plate: https://tinyurl.com/5cwsyxfy
Old Sep 5, 2021 | 11:10 AM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
Best option for the rear plate: https://tinyurl.com/7v8aksut
I had them on my Targa GTS and now on my Spyder - perfect!
Old Sep 5, 2021 | 12:55 PM
lowbee's Avatar
lowbee
Originally Posted by edub
Rear Plate
I like the rear plate idea and I might just do that......for the front, I am going with Carbonio
Old Sep 5, 2021 | 05:08 PM
edub's Avatar
edub
haha. Yeah off center is a different aesthetic. Since I can't avoid running a plate, this one puts the plate out of the way of functional vents/radiators and out of sight for 3/4 angles.
Old Jan 27, 2023 | 03:45 PM
edub's Avatar
edub
Update - I've taken these plates off several times for track days and washing. After 12,000 miles everything looks and holds as good as it did day one.
Old Jan 27, 2023 | 04:38 PM
ANGST's Avatar
ANGST
Yep, this is what I have on my 718 GTS too.
Old Jan 27, 2023 | 06:18 PM
nineball's Avatar
nineball
i just drilled a hole in the middle of the plate
Old Jan 28, 2023 | 12:57 PM
Aronis's Avatar
Aronis
Did same, bought a kit with all sizes of grommets and screws, it's pretty handy for other projects.
The front I did with an under car mount, no touch on front bumper.
Mike
Old Sep 30, 2023 | 06:17 PM
sonicworld's Avatar
sonicworld
So can someone fill me in on what this is all about? Does Porsche not provide holes for mounting the rear plate?
Old Sep 30, 2023 | 06:22 PM
edub's Avatar
edub
Says what the issue is in the first couple line of the first post.
Maybe you were asking something more specifically?
Old Sep 30, 2023 | 08:58 PM
Aronis's Avatar
Aronis
Mine had plate screwed into the plastic bumper by dealer. I added proper nuts as the person above did.
Auto manufactures have gotten pretty lazy with plate mounts. Kind of a shame if you ask me.
Mike
