718 Forum 982 (718) 2016-Current Discussions about 718 Boxster Cayman Variants
Scrap Amor
Old Apr 7, 2021 | 10:48 AM
Ryan391's Avatar
Ryan391
Default Scrap Amor
I just purchased a 718 GTS last week. Coming from a 911 Carrera base, the 718 is awesome. One main difference is the 718 GTS has PASM and the lower ride height has caused me to scrape my front bumper on the drive way. I saw a product called Scrap Armor. They make a 718 package, but not a GTS package. Has anyone used this? Are there any competing products that offer a GTS package?
​​​​​​https://scrapearmor.com/?utm_source=...8aAvGsEALw_wcB
Old Apr 7, 2021 | 08:57 PM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
SlipLo - many of us use it and I had it on my Targa GTS and I already bought it for my Spyder:
https://rennlist.com/forums/991/1199...on-sliplo.html
And there is a discount in the thread as well.
Old Apr 7, 2021 | 08:59 PM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
And there is a discount in the thread as well, or here:
https://sliplo.shop/bob-ziolkowski
Use this code for a discount: 488310EA35A
Old Apr 7, 2021 | 10:01 PM
Ryan391's Avatar
Ryan391
Default Sliplo
How many do I need for a 718?
Old Apr 7, 2021 | 10:03 PM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
The standard kit for enough for my 991.2 so it should suffice for the 718, and that is what I got for mine. As a heads-up, trimming them, if need be, is easier with tin snips, or powerful scissors.
Old Apr 8, 2021 | 03:46 PM
Spyderman2's Avatar
Spyderman2
I have that trouble with my Spyder when entering the driveway at my son's house. But the scraping can be avoided with many driveways simply by entering the driveway slowly at a 45 degree (+ or -) angle instead of straight-on. Try that before adding clap-trap to car.
Old Apr 8, 2021 | 03:48 PM
Ryan391's Avatar
Ryan391
I have found I have to do this too.
Old Apr 8, 2021 | 03:54 PM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
Clap-trap? When installed along the front edge it actually looks good as well as to prevent scraping underneath...one may not like it for some reason but more than not feel the opposite.
7 Porsche Models That Have Aged Like Fine Wine
Old Apr 8, 2021 | 04:00 PM
Ryan391's Avatar
Ryan391
I like the sliplow look, but I have some scrapes already, Trying to decide if I should fix or just put the slipl low over it.
Old Apr 8, 2021 | 04:04 PM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
SlipLo is much cheaper and you can sand out some scratches and put it over them, which is what I did. SlipLo also helps to make the lip more rigid so it you were to whack it real hard it will save your spoiler lip so it is cheap insurance. I started using it over 25 years ago on a 1st Gen Viper and have continued every since.
Old Apr 9, 2021 | 06:06 AM
randombum's Avatar
randombum
Does anyone have experience trying to remove sliplo? The website has a note saying it's removable, but gives no detail how that would happen. Of course pretty much anything is removable just a matter of how much damage you do. Doesn't seem to jive with the fact that it must adhere so strongly to work.
Old Apr 9, 2021 | 09:20 AM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
Yea, with some heat. I put a piece in the wrong spot and since I used the adhesive promotor I did not want to risk pulling off paint so I warmed it up, peeled it off and repositioned it.
Old Apr 9, 2021 | 02:34 PM
Archimedes's Avatar
Archimedes
This is the problem I would have with it. Aside from the fact that it uses up even more clearance, it looks like it is rigid and would transfer more force to the bumper in a firm scrape, which isn't what you want. The stock lip has some flex in it so it gives a bit, avoiding ripping the bumper off the car. There is a reason why the stock spoiler lip is cheap flexible plastic.
Also, all this product does is protect from scrapes underneath, which you never see anyway.
Old Apr 9, 2021 | 04:01 PM
Bob Z.'s Avatar
Bob Z.
Veteran: Navy
No offense but you are over thinking it...it is thin. sturdy material and once it is trimmed back there is no way it would make any situation worse, but to each their own. All I can say is I have used it for a long time and nothing negative has occurred.
Old Apr 9, 2021 | 05:05 PM
Archimedes's Avatar
Archimedes
But what did it save you? Was it cheaper than just putting a new plastic lip on 5 years down the road? Do you regularly get down on the ground and look at the bottom of your splitter?
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
