718 GTS - 1st Buttonwillow Track Day Review
I’m also considering if I should mod my 718 S this year or go for the GT4. Only 1 Porsche for me so leaning towards the GT4 since it’s a nice blend of everything and in the long term the extra $ upfront should equal out vs the depreciation of a non GT car. I’ve probably already lost 35k depreciation on my current car so it’s a tough pill to swallow going to the GT4. Trying to do mods that I can possibly transfer to a GT4 like the DSC controller.
if you only have one Porsche in the garage period can’t go wrong with the GT4 - it will absolutely hold it’s value better than the current 4 cyl the car is gorgeous and it will happily hop on and off track duty. It’s still somewhat hard to justify the min $20K jump in price but the fact it will hold value longer helps that out. From what I’ve seen so far the actual GT4 isn’t a huge leap in performance compared to the GTS and that slight gap is easily made up in aftermarket - for someone looking to get a “cheap GT4” I’d wait for all the GTS turn-ins for GT4 upgrade vehicles and sneak one out with low mileage for a steal, slap an APR / Cobb Tune and upgrade the suspension all for less then $5K including install and have fun taking the new GT4 off the line and keeping up in the turns.
install ran me $350. You can hit apexs at speed and not feel unsettled. This plus DSC and maybe if you want to really go track specific rear control arms. But with the front LCA you can dial in camber which I highly recommend.
temps were quite cool - Jan in CA. I ran a pretty hot day at ACS last Oct and no issues at all. The GTS has the third radiator and bigger turbo. The S seem to have the turbo heat soak issue.
I thought they were the same size.
also variable vane, etc
GTS definitely has the 3rd radiator, which helps against heat soak, as you said.
Also, thanks for sharing.
2.8 deg is a good amount of camber on the front which I assume you can dial in with the lower control arms rather than having camber plates? Just wondering how it affects straightline braking?
Any plans to improve front downforce? In my experence on lower speed corners (30-60mph) with larger rear tires the rear is quite well planted but the front can have the tendancy to understeer a little when pushed although I'm only running 1.4 deg camber which is maximum on OEM suspension.
Just curious about the bump steer... You got and installed the ajustable Tie Rod Ends, correct?
Since my car is also going to be my primary DD with some track duty too, I bought upper camber adjustable plates and plan to run max -2.0 to -2.2 camber upfront... Would you still recommend the ajustable Tie Rod Ends for me?
The car is a GTS and as such is 20mm lower than a regular Cayman and I'm sure Porsche does not make a different OE Tie Rod End for the Base, S and GTS Cayman.
Also bought track dedicated mags, 9X18 upfront and 10x18 in the back with R compound tires, S/S braided brake lines and the complete Girodisk (F+R) brake kit with their stud conversion.
It is my understanding that bumps steer correction is only necessary on highly lowered car. The longer arm of the bump steer correct the affected geometry of the steering arms in relation to horizontal due to lowering the car. Did you lowered the car? I’m I missing something?
Thanks for the info.
Update! Second day at Buttonwillow this time with OnGrid. I was invited to compete in their Shootout in the Sport Class. Basically stock everything minus the minor adjustments to add camber and a "factory" GT4 wing (same specs as a GT4 anyway). Right off the bat I was much more comfortable in the car and on the track. I was also in a time attack event where 80% of the drivers are all sub 2:00. Being on track with faster drivers and less traffic really allowed me to perfect my lines and when I was able to stay behind faster drivers (before I got gapped) and holy **** did that help my time. I went from trying to average a 2:06 and snuck in a single 2:04 to averaging 2:04s with the occasional 2:05. My 3rd session I noticed I was pushing / on-tilt so I left track early (still getting 3 2:05s). Last session of the day I made it my focus to stay behind the #2 position driver who was averaging 2:02's and really follow his lines, reduce my lift and carry momentum. For those that have never been to Buttonwillow there is no single turn or area you can miss to get a better time- meaning you can't make it up on a straight. You have to hit the turns exactly right, brake early many times to carry speed and accelerate perfectly out-of-apex. The only thing I did was upgrade brakes to Ferodos and that was a massive improvement. It gave me way more confidence on my braking, let me hold my lines and allowed me to brake in-control.
Last session of the day I got a 2:02 and 2:03 before I exited track. And it was the easiest drive I had it felt great. This car absolutely has a sub 2:00 in it as-is and with Recaros and slightly better tires I think I can grab it. One more thing to give props to the 718 GTS 4 banger- my car - compared to every other car that was in the shoot-out- was the most "stock" car there. Stock seats, no tune, no roll cage / harness, not lowered, no "cheat tires" etc. Every other car in the group was heavily modified kudos to Porsche for making a car you can drive onto the track, drive home, give a wash to and still have an amazing daily driver.
The following 5 users liked this post by mdr911:
k.alexander (02-10-2020),
matttheboatman (02-10-2020),
PorscheMeister42 (02-12-2020),
sobiloff (02-10-2020),
Vgj (02-10-2020)
