brake pad
brake pad
2018 718 Cayman GTS. 12000 miles mostly street and occasional track use. Downsized to 19" wheels for the track.
New rear brake pad (OEM) cracked after 1 track day. Enough heat was generated to melt the sensors.
Defective pad? Anything to do with downsizing? Original brakes worthless for the track?
What do the brake rotors look like, have cracks developed around the cross drilled holes? also try Pagid RSL29.
https://www.porsche.com/internationa...vectoring-ptv/
The 718 GTS has PTV standard. It is a limited slip differential with some electronic aides that use the rear brakes.
