718 Forum 982 (718) 2016-Current Discussions about 718 Boxster Cayman Variants
Porsche 718 turn off during traffic light and won’t start
Old 01-27-2019, 04:19 AM
Max3wheeler
7th Gear
Max3wheeler's Avatar
Default Porsche 718 turn off during traffic light and won’t start
I have a problem with my 718, when ever I stop at traffic light the engine turn off as normal auto stop start function. But, it won’t start automatically. What could be the issue?
Old 01-27-2019, 05:59 PM
Max718-19
Max718-19's Avatar
Manual or PDK?
Manual requires clutch depression in neutral to startup.
uto Start/Stop Function
When the vehicle stops, e.g. at a traffic light or in a traffic jam, the engine automatically stops, provided all the requirements for the auto stop function are met. In addition, the engine can also stop automatically when the vehicle stops while moving at walking speed. In this way, the automatic Start/Stop function helps to save fuel. The ignition remains on, even when the engine is stopped automatically. All safety functions continue to operate.
Prerequisites for the auto engine stop
  1. Auto Start/Stop function switched on.
  2. Luggage compartment lids are closed.
  3. Engine, transmission, and air conditioning have reached operating temperature.
  4. The vehicle has traveled at least at walking speed since the last auto engine stop.
  5. Vehicles with PDK:
    Brake pedal pressed.
    Selector lever in position D, N, or P or manually selected drive position 1 or 2.
  6. Vehicles with manual transmission:
    Seat belt fastened and driver’s door closed.
    Gear lever in neutral and clutch pedal released.
Vehicles with manual transmission: engine stop and start
Engine stop
  1. Brake the vehicle with the footbrake.
  2. Move the gear lever to neutral.
  3. Release the clutch pedal.
    The engine stops.
Engine start
  1. Seat belt fastened.
  2. Driver's door closed.
  • Press the clutch pedal.
    You can move off as normal.
Information
In certain situations, the engine is started automatically, e.g., if the vehicle is rolling forward or in order to maintain a comfortable temperature.Vehicles with PDK: engine stop and start
Engine stop
  2. Press and hold the footbrake. – or –
    While stationary, move selector lever to P.
Information
The HOLD function can be activated by quickly flooring the pressed brake pedal while the vehicle is stationary. This keeps the vehicle at an engine stop without the brake pedal having to be pressed continuously.
  1. Please see chapter "HOLD Function: Drive-off Assistant, Standstill Management" on page 121.
The engine starts automatically when the accelerator pedal is pressed or if the engine needs to be started.Information
If the adaptive cruise control (ACC) is switched on, the engine stops automatically when the vehicle is stationary, if the vehicle ahead also comes to a halt.
The vehicle is held in a stationary position by the HOLD function.Engine start
  1. Selector lever in position P, D, N or manually selected gear 1 or 2.
  • Release the footbrake (not in selector lever position P).
    – or –
    Press the accelerator pedal.
    – or –
    Move the steering wheel.
    – or –
    Select PDK selector lever position R.
    You can drive off normally.
Old 02-05-2019, 09:02 AM
Max3wheeler
7th Gear
it’s pdk . It just stall & I need to restart the car again
Old 02-05-2019, 09:13 AM
Max3wheeler
7th Gear
Plus the auto stop start is off
Old 02-05-2019, 11:20 AM
DriveInHouston
DriveInHouston's Avatar
Does it stop in the Sport Mode?
Old 02-13-2019, 08:25 AM
Max3wheeler
7th Gear
With sport on or off , with auto stop start on or off it just engine stops and you have to restart the car at stop light & traffic . Even the dealer don’t have a clue.
Old 02-13-2019, 09:10 PM
GregWormald
GregWormald's Avatar
It's the dealer's obligation to service the warranty--even if they don't have a clue at present. It sounds to me like it's time for escalation, by the dealer or you if they are not being prompt in getting it fixed.
Old 02-14-2019, 01:45 AM
Max3wheeler
7th Gear
One time they reprogrammed it and it worked for 3 weeks then it happened again
Old 02-15-2019, 04:55 PM
visitador
visitador's Avatar
At this rate, you'll have to start recording the times the dealership failed to fix the same issue. May as well familiarize yourself with the lemon laws of your state.
Old 02-18-2019, 01:34 PM
lajoiedp
lajoiedp's Avatar
I had this same situation come up the day I had my car delivered. It has something to do with the order in which the auto start stop function is activated with relation to putting the car in sport mode. I can’t remember the exact sequence that causes that to happen but I had to call my sales rep who talked to someone in service to get me the answer.
Exceptional conditions for the Auto Start Stop function
The Auto Start Stop function is not available in the following cases, for example:
When SPORT/SPORT PLUS mode is activated.
Old 02-18-2019, 03:33 PM
DriveInHouston
This is not correct.
You start the engine and put the car in Sport/Sport Plus and the Auto Stop/Start is deactivated.
You start the engine, stay in the Normal mode, press the Auto/Start button and the Auto Stop/Start feature is deactivated
You start the engine and go, the Auto Stop/Start feature will be enabled under the conditions specified in the manual (engine warmup and others).
You start the engine, press the Auto Stop/Start button and then the Sport Mode button, the Auto Stop/Start mode is deactivated. If you get OUT of the Sport Mode, the Auto Stop/Start mode REMAINS deactivated.
You start the engine, go to Sport mode and then press the Auto Stop/Start button, nothing happens. You get out of Sport mode and the Auto Start/Stop feature is activated as if you hadn't pressed its button while in Sport Mode.
Are there any other sequences that I missed?
Quick Reply: Porsche 718 turn off during traffic light and won’t start
