2017 Boxster Wheels rubbing
Hi all,
I recently purchased a 2017 Boxster base with 235/40ZR19 yokohamas on. When taking tight turns in the parking lot, I hear rubbing sound (not quite sure, also sounds like the tires sliding). Does anyone have any insight on this? Thanks all!
my 2019 718 Boxter s does the same thing. I believe the engineering on this is that the turning ratio for the "inside wheel" (inside wheel defined as the wheel in the direction of the turn) is different than the outside wheel, therefore one wheel will skip on the pavement until they can get in sync with each other as the wheels catch up with each other as they goe around. Not dissimilar to the ratio differential in a 4 wheel drive vehicle that hops across the pavement as you turn on the 4 wheel drive.
Received 1,675 Likes
Totally normal. Expected with big front tires. Nothing directly to do with limited slip or not, unless the LSD is locked up at a high ratio (i.e. broken.)
Here: https://en.wikipedia.org/wiki/Ackerm...ering_geometry
