High Gloss Black vs Jet Black Metallic wheel paint?
Hi everyone,
I'm having a hard time seeing the difference between these two wheel paints on the 20" Carrera S wheels in the online configurator. Does anyone know of any comparison photos, or even good photos of each wheel by itself? Opinions are welcome, too!
I have a deposit down on an allocation for a Cayman GTS and am having a hard time deciding which color to go with. I want black wheels. If I go with the High Gloss Black on the wheels I'm guessing I should go for the Window Trims and Window Triangles in High Gloss Black as well? If so, that'd make me lean towards the Jet Black Metallic to avoid having the window trims painted as well.
I haven't seen the Carrera S wheels in gloss black or metallic black. Personally I think the satin black looks fine unless you have a lot of glossy black parts on the car which you probably don't. I would think you can always get them painted gloss black later if you wanted for less than it costs you from Porsche.
I did see this very nice Cayman GTS in GT Silver with the Carrera Sport wheels in gloss black. This car also has gloss black sports design package so I think it looks ery good but I don't think the extra cost is worth it. GT silver looks great with satin black wheels.
What colour will your car be?
Cayman 718 GTS in GT Silver with Gloss Black Carrera Sport Wheels
I also took some photos of the Satin black wheels on a white GTS, also looks great.
Satin Black Carrera S Wheels
Thanks, DonR!
THANK YOU msacks! That indeed is the look I want. Did you happen to get the "Window Trims and Window Triangles in High Gloss Black" option as well? Frankly I'm not even sure what those parts are, since the online configurator doesn't seem to show a change when you select that option.
Here's a picture of what the Porsche Window Trims and Window Triangles in High Gloss Black Porsche Exclusive Manufakture is:
Thank you again, msacks!
