Weather strip
My front and rear glass weather stripping is cracked / separated and looks horrible (not leaking though). I am assuming to replace, the glass has to be removed? That REALLY makes me nervous. What is the success rate of doing this and not breaking the glass? Would a reputable windsheild repair place be ok?
Thanks guys
Thanks guys
Miserable Old Bastard
Haven't done it but I've heard it can be tricky and if you're not careful, you can crack a windshield (going price for new ones is about $500+). I guess is a good windshield repair place is willing to take the job, they should be responsible if they break the windshield. Check the Registry Technical section - I think there may be an article there re changing windshields - there are some special techniques.
OK, I checked for you, check this article: http://www.356registry.org/Tech/windshield.html
Yes, the glass has to come out. I'd seek a 356 restoration shop that has plenty of experience installing glass - I suspect there are a number of them in FL. I have read that even new gaskets will develop cracks at the corners fairly soon after installation, so be prepared for that. in my case, as long as I've got no leaks, I'm not screwing w/ them (it won't be seen on the lawn at Amelia Isl anytime soon, though). & as we all know, as soon as you replace a ws you get stuck behind an uncovered gravel truck... good luck!
Really........... don't replace it unless you have to. We replaced one on our '65 and within a year, the new one was cracked in the exact same corner. That was the end of that car's Concours life. We weren't about to take another chance and have the windshield (original to the car) break just to have the car look 'better' for a bunch of judges......
Ok, you talked me out of it. I feel better though knowing that I am not the only one running with cracked stripping. My girl is a survivor not a show car anyway. Had a "spirited" drive this morning and my 356 juices are flowing! I will focus my $ towards something a bit safer....
If you do decide later, the glass should be fine however remember that you may have to replace the window trim.
When I did mine...(or the shop for that matter) they bent the trim on both front and rear, so off to Stoddard.
FYI on prices:
Front rubber $61.50
Rear rubber $70.75
Trim front $44.50 and 45.90
Trim rear $44.45 x 2
Connecting piece $4.25 x4
FYI on prices:
Front rubber $61.50
Rear rubber $70.75
