Vehicle Marketplace - Old A place for Rennlist Members & Sponsors to sell their new & used vehicles.
Mark this thread as Unsold
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Cont. Porsche Models:
Mileage (numbers only please):
Color:
Price (no $ sign please):
Private or Dealer Listing:
Location (Region):
Transmission Type:
Parts Search
Keyword:
Category:
Private or Vendor Listing:
Location (Region):
Item Condition:
1986 Porsche 944 Turbo - RS Martini Tribute - FL
Old 02-25-2017, 06:42 PM
RockStar951
RockStar951's Avatar
Default SOLD 1986 Porsche 944 Turbo - RS Martini Tribute - FL
Year: 1986
Make: Porsche
Model: 0
Cont. Porsche Models: 944 Turbo
Mileage (numbers only please): 86000
Options (Please check ALL which apply): Foglamps, Power Windows, Sunroof
Color: White
VIN: WP0AA095XGN152168
Price (no $ sign please): $10500
Private or Dealer Listing: Private Listing
Location (Region): SouthEast
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Turbo
Stereo System: AM-FM Cassette
Car: 1986 Porsche 944 Turbo
Specs:
Car was purchased with no motor installed. Spent 1.5-2 years building the car into the current state. Wanted to build a RS/GT3 Inspired 944T/951.
No time to drive. Too many cars and too much work.
Engine:
- Factory 2.5L motor
- Normal spec KKK, K-26
- Lindsey Racing Boost Enhancer
- Stage 2 Tune from Auto Authority
- Shimmed factory wastegate
- All new hoses, Vacuum and water
- Vacuum lines are silicone
- New Clutch, Pressure Plate, Master Cylinder, Slave Cylinder, and lines
- New Timing Belt
- New Battery Cables
- New braided fuel lines on motor.
- New plug wires and dist cap
- Tested all lifters in Cam Tower and replaced any bad ones.
- Tons of new sensors on the motor, I spent at least $500 on misc sensors.
- AC and Heater not hooked up.
- NOT GOING TO FIND A CLEANER ENGINE BAY ON A 944
- Car comes with spare Block
Interior
- Suede wrapped dash
- Suede wrapped RS Style door Panels
- 2 fiberglass buckets w/ Race Harnesses
- Custom rear seat delete
- Rear trunk area carpeted smooth.
- Suede shift ****
- NOS Blaupunkt style Radio
- Switched to Porsche Manual Roof Mechanism over the power, preferred by other owners as electric is a PITA.
- Power windows. Manual door locks and mirrors.
Outside:
- 3PC Turbo Twist wheels
- Have factory phone dials also.
- Now has Martini Racing stripes and small decals
Price: $10,500
Serious Inquires Only Please.
THANKS FOR LOOKING!
RockStar951 is offline
Old 02-25-2017, 09:33 PM
Bluejays42
5th Gear
Bluejays42's Avatar
Will it pass smog in california? And if the answer to the first question is yes, would you recommend this exact car to a 16 year old?
Bluejays42 is offline
Old 02-26-2017, 09:57 AM
pontifex4
pontifex4's Avatar
Pretty car, good luck with the sale.
Just one caution about those harnesses -- the shoulder belts should not be used in that configuration because they are anchored too low. There are a couple of different harness bars which you can get to anchor them properly and they're inexpensive and easy to install.
pontifex4 is offline
Old 02-26-2017, 12:35 PM
911-140.6's Avatar
Very nice but why the heck would one disconnect both the AC and the Heater ? I would consider paying close to your asking if both were working. Is that possible ?
911-140.6 is offline
Old 02-26-2017, 01:24 PM
u7t2p7
u7t2p7's Avatar
why would any responsible parent purchase a car like this for their child, other than living vicariously through them. Poor visibility, lack of today's safety features, propensity to speed (16 year olds are very impressionable), etc etc. Do you and your kid a favor and start them out in a slow, safe and reliable car. Golfs and Jettas come to mind.
u7t2p7 is offline
Old 02-26-2017, 02:48 PM
TheFatArmenian
TheFatArmenian's Avatar
I am pretty sure, it is the 16 year old asking ;-)
TheFatArmenian is offline
Old 02-26-2017, 08:52 PM
Bluejays42
5th Gear
Bluejays42's Avatar
Thank you Armenian, I am.
Old 02-27-2017, 11:15 AM
PPo
PPo's Avatar
Totally not a car for a 16 year old. They are reliable and great cars, but need attention often.
Also, these cars will get you into trouble faster than most. It's not really the acceleration as minivans these days are getting fast, but it's the cornering ability, the brakes, and the overall positive confidant feeling these cars provide. You will get too cocky and end up doing something stupid. I had one of these in my mid-20s and it was still questionable if it was a good idea!!
Also, you need a garage filled with mechanics tools and the knowledge on how to use them to sensible afford one.
Hope that helps...
PPo is offline
Old 02-27-2017, 11:17 AM
PPo
PPo's Avatar
Also... what a gorgeous car!!! Well done!
PPo is offline
Old 02-27-2017, 07:39 PM
Bluejays42
5th Gear
Bluejays42's Avatar
Thank you PPo. My dad also owns a Porsche shop and has lots of help and tools there. We also have a lift and tons of tools at home. I am actually planning on using it for autocross because my dad is a member of PCA and I will be too if I get one. Thank you for your input.
Old 02-27-2017, 11:21 PM
RockStar951
The car is a fair weather car, as it has lived in FL for its known life. As for the heater, I have never hooked the coolant lines to it to ever test since it never gets cold enough in FL. Never wanted to find out if the heater core leaks or not.
Regarding the AC, I actually have a rebuilt compressor that has not been installed. So installing the compressor and a new dryer should have you in good shape. I have not tested the electricals for the AC but everything is as it should be.
Thanks for the question.
Old 02-27-2017, 11:23 PM
RockStar951
The car is CAT Delete so I do not advise it for a SMOG CA check. No sniff tests in FL.
I would consciously recommend a 951 to a new driver.
THX
Old 03-10-2017, 10:19 PM
RockStar951
Old 03-12-2017, 02:19 PM
wheels5550
wheels5550's Avatar
This is very tempting. Considering putting my 84 NA up for sale to make room for this.
wheels5550 is offline
Old 03-12-2017, 06:47 PM
Jferrante
Jferrante's Avatar
wouldnt mind dallying this - no heat/ac is the dilemma
Jferrante is offline
Quick Reply: 1986 Porsche 944 Turbo - RS Martini Tribute - FL
