Mark this thread as Unsold
Boxster S Race Car
Boxster S Race Car
Year: 2000
Make: Porsche
Model: 0
Cont. Porsche Models: Boxster S
Mileage (numbers only please): 112584
Color: Silver
Price (no $ sign please): $34500
Private or Dealer Listing: Private Listing
Location (Region): SoCAl
Body Style: Coupe
Transmission Type: Manual - 6 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
Larger oil cooler
Larger 996 based brake calipers with cross drilled rotors
Heavy duty rear uprights (larger wheel bearing than the non-s upright)
Center “3rd” radiator
Boxster S front bumper
Non traction control car
Bare tub build (everything was removed and inspected)
Bare tub pressure washed and hand scrubbed
Front and rear sub frames were walnut blasted
Suspension
Bilstein PSS
Swift 560lb Front and 672lb Rear springs
Tarett long drop links in front
RSS Billet adjustable control arms (F+R)
RSS monoball adjustable toe links (F+R)
996 GT3 5 way adjustable front sway bar
Brakes
Stainless braided brake lines
Pagid racing brake pads (Orange Front, Black Rear)
Larger Boxster S calipers
Ported Boxster S rotors
GT3 front brake air ducts
Interior
TIG welded DOM Professional roll cage by TC Design
Momo Daytona XL full halo seat on factory sliders via Brey Krause seat mounts
Schroth 6 point harness
Window net with spring plunger quick release and heim joint on the other side
Momo steering wheel with quick release
fire extinguisher
Electrical Stripped down wiring harness removing 20+ lbs of weight
GT3 Cup Pro Electronic kill switch (driver inside switch and cowl button)
Exterior
Wide front fender flares
Front and rear GT3 Cup tow hooks
Fully painted 10lb composite top with integrated convertible cover with Lexan rear window
Gutted doors
Engine\Trans
3.2 liter M96 engine
Engine was pulled from another 2000 Boxster S with 42k miles
New belts
New spark plugs
IMS upgrade
X51 oil pan
New front and rear main seals
EGR block off plates
Underdrive pulley
High flow headers
Straight pipe exhaust
New factory Porsche 6 speed transmission with about 20 hours on it
Balanced Aluminum flywheel with new clutch
This car ran a 1:24 at Streets of Willow on used slicks with 8 heat cycles and the track temp was 116 degrees.
Built by Brad Roberts. Possible trade for Cayman and accepting offers
email me at ShannonLew@gmail.com
