Mark this thread as Unsold
FS: E46 M3 race car - Spec GTS3/4 - HPDE
Year: 2002
Make: BMW
Model: M3
Mileage (numbers only please): 0
Color: SILVER
Price (no $ sign please): $55000
Private or Dealer Listing: Private Listing
Location (Region): SoCAl
Body Style: Coupe
Transmission Type: Manual - 5 speed
2 or 4 Wheel Drive?: 2 Wheel Drive
Engine Type: Fuel Injection
Stereo System: None
Sale Price $55,000 Or better offer
I ran this car with many of CA PCA guys and had a lot of fun chasing my friends. I have never raced this in wheel to wheel and built this for just HPDE events but wanted to have a safe and fun/reliable car that I can learn how to drive. Prior to this car, I started with 997.2 GT3 and it was a very difficult car for someone who didnt have a lot of experience. So I decided to build a full blown E46 M3 race car which is much easier to drive due to neutral chassis balance. Time to move on different car for different experience.
ONE of the fastest, cleanliest and professionally built/maintained E46 M3 race car – $90k+ to replicate
Bought best race parts and always refreshed items and pre and post track inspection with meticulous care.
Car located and stored in SoCal - I have title in hand and registered as Non OP in state of CA.
• 342 RWHP/ 273 Torque – Dyno Sheet available – can be detuned or add weight for diff class requirement - GTS 3/4 or keep it as a super fun HPDE car.
• Weight: 2650lb with FULL 16 gallon fuel WO driver
• Donor car had 144k miles – Brand New S54 motor from dealer at 61k chassis miles (Due to Rod bearing) – VIN number will show that in BMW dealer system. 94k on motor when car got converted to full blown race car. Previous owner (CA car) changed oil every 3500 miles and he was the only owner since purchased. He gave me 12 years of service documentations. I am the second owner and did about 25 days of HPDE.
• VERY clean engine internals
• Valve adjustments, Full VANOS rebuilt/refreshed , Rod bearings done
• Originally was SMG transmission – converted to 5 speed
• Primarily used for HPDE but it is race legal in specs in most recognized sanction (NASA/SCCA GTS3/4) ZERO accident. Original Frame. Original Paint.
• Meticulously and professionally built/maintained at race shop. This is not a home garage project. GSR and Trinity Autosport in Anaheim, CA (changed name but same place) built and maintained.
• Any wear and tear parts were replaced to ensure full functionality of the car and if any part needed to be replaced, it was replaced without hesitation for safety and performance of the car.
• Very reliable and fun and FAST car.
• Some track times (I am not the best and most talented driver – put this car in hands of a pro, it will probably be one of the fastest cars for its weight/hp)
• Car is READY to be enjoyed immediately
Engine
STOCK S54 motor – Tuned OEM ECU
VANOS Rebuilt with CYRO treated VANOS Exhaust HUB
All new gaskets and seals/hoses
New Coil packs, new spark plugs
Changed motor oil, trans oil, diff oil every 4-6 events
MODS:
Refreshed Turner Pulley kit/ Idler w new belts (2016)
AC/HEAT core Delete
BW Water pump
AFE Intake
Supersprint V1 Step headers + BW 3.5 inch straight exhaust
New Wheel bearing HUBS all four corners for 2016
Brembo 355/345 w ST43 brake pads – new rotors in 2015 nov (have 6 days on them) – Just put brand new front pads. 6/2016
BW Oil Diverter Valve
C&R Alum radiator w 16inch SPAL electric fan – all hoses replaced
Setrab custom oil cooler with Kevlar lines
BW CF Brake duct intake and hoses
Secondary Fuel pump to prevent fuel starvation
Full AKG Solid Mounts – Transmission, Differential, Motor
BODY :
MA Shaw FG side doors
MA Shaw FG Trunk
No sunroof – car has “slick” top – Sunroof was not ordered when car was built from the factory
OEM Alum hood – weigh reduced to 17.5lb (vs CF hood 15lbs)
Rear and quarter Lexan window – Front is OEM glass
AJ Hartman CF Canards
Full Custom CF front splitter mounted to chasis (via custom frame)
Brooks Motosport Rear wing Stage 2 with Custom uprights to Frame of the car.
ARP CF Side mirrors
Aerospace latches for hood and trunk
SAFETY:
Custom Rollbar legal for NASA/SCCA – rear tower tied
Lifeline Fire system
Cartek GT Battery Isolator/killswitch
INTERIOR:
Sparco EVO II Halo seat – one year old
SCHROTH 6 point harness – chassis anchored
Longacre 17 inch rear mirrors
Lithium Lightweight Battery (4 lbs) (New 2015)
SUSPENSION:
JRZ RS PRO with custom mounted remote canister – True rear coilover setup
F: Swift Spring 15kg/ helper spring
R: Swift 7kg/ helper springs – True coilover rate
Full solid Bushings: AKG Trans, Motor, Diff
Front GC SWAY/ Rear OEM CSL Sway
Treehouse FCAB
Turner Motorsport Rear Lower Camber Arm
Turner kit Rear subframe welded
New wheel studs (refresh annually)
DRIVETRAIN:
Custom driveshaft for 5 speed trans box
3.91 ratio OS GIKEN Differential w polished pinion,
5 Speed E36 M3 Transmission (~40 lb lighter) (new 2016 )
Clutchmaster Stage 4 clutch and light weight flywheel (new 2016)
CAE Shifter - one of the best shifters on the market (2016)
New half-shaft rear (10 days on them)
New Rear trailing arm (10 days)
WHEELS:
4 x APEX ARC-8 White 18x9.5 ET22
4 x Enkei NT03 18x 10 ET25
Mounted tires are BFG R1-S 275/25/18 (two sets with 12 HC)
Historically, I ran 26 HC with very little drop off in performance.
I have gutted OEM doors and trunk in storage as well.
This car is very economical to run, very reliable and easier to drive near limit fast!
Some track times: I have far less experience than some of you at the track. But these are some of the times I clocked. Im sure in the hands of better driver, lower times can be seen.
Thunderhill 3 mile bypass – 1:56
5 Mile cyclone and bypass west side - 3:12
Buttonwillow 13CW – 1.53
1.49 done with a very talented driver
PIcture link - https://flic.kr/s/aHskCzgPht
I will be getting more pics of the interior probably end of next week.
Also have 2013 TPD Vortex 24 ft trailer for sale – One of the best custom trailer with high quality build trailer. Custom trailer w AC, cabinets, - Orginal price - $28500 + tax. SALE price $20k All bearings and new tires.
PLease email/PM me with questions revmatch640 at gmail
The Porsche Eater is what I call that thing.
Car is fast and well done.
GT3 player par excellence
i know the car
very nice
very fast
and i think you priced it wrong.
should be 10k more
very nice
very fast
should be 10k more
"Porsche eater"?? LOL.
Thanks for the kind comments guys.
Priced it so buyer gets ready to go full blown race car that is all dialed in on the track ASAP. No work is needed. Wel. I'll give it a nice detail. Yes I do wax and wash this car like a street car
Buy with confidence. I've see this car many times and it is well taken care of and nicely set up. GLWS.
What's next?
What's next?
beauty and nice comments. wish i could buy it and replace my E36 racecar..
Originally Posted by golfnutintib
ooooooooooohhhhh
what's next dave??????????????
